Results 1 to 10 of 20
Thread: Vectra c fob re-syncing correct procedure please
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Default Vectra c fob re-syncing correct procedure please
    Hi all
    ive fixed reverse lights. Bulb and pad warnings next Is fob.
    Ive read about 3 different re-syncing procedures and need a definite explanation before I pay out.
    Vectra 1.8 ls 52 plate c newer shape with 3 button remote ie including boot.
    The fob was a bit worn so I had a look and the battery is ok but found a button unsolder end and the battery terminal dry joint so I've fixed these faults
    i get 3v at buttons and when pressed they drop to 1.5v for a few seconds. I don't see an led and its back together now but does nothing.
    Does anyone know the exact procedure for this car.?
    or a test to see if the fob is transmitting. Would a radio receiver set to 433mhz hear it ?
    cheers
    barks
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    To re-sync a fob to the rentral locking, pop the key in the ignition and turn it to the second position (ignition on). While on, press the lock and unlock buttins around 3-4 times each, then turn off and key out. press the lock button and it should start working again.
    This will only work if the key is programmed to the car previously. Change of battery or repairing the buttons should get away with the above procedure
    13 Post(s)
    Put key in ignition and turn to position 2.
    Press lock/unlock buttons.
    If resync is sucessful, the C/L should operate.
    There is also another procedure mentioned in newer handbooks too:-
    Unlock door with key in lock. Inserting the key into the lock synchronises the radio remote control. Now whether the latter refers to the door lock or ignition lock, I have no idea.
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Thanks both.
    Ill give it another go.
    Does it not matter if door is open or closed ?
    cheers
    barks
    Nov 2011
    No idea, but lets say Closed
    13 Post(s)
    I've alwasy done it with the door open. No idea if makes any difference or not.
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Cheers all
    ive tried it all ways and nothing.
    I don't think the fob is transmitting but I have no way of testing
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    battery?...does the red light in between the buttons light up when you press the buttons?
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Quote Originally Posted by nikroc View Post
    Has anyone got a wiring diagram for a 3 button remote fob?
    many thanks
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    its a circuit board setup,battery change/check light is a good,simple start.
  1. Correct tyre size? (52 reg vectra SXI 16v 2003)
    By kona_uk in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2012, 11:42
  2. Boat launch procedure...
    By JohnnyB in forum Comedy & Humour
    Last Post: 7th August 2009, 17:02
  3. Gearlinkage adjustment procedure
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2009, 09:10
  4. max wheel size for vectra-c/correct offset?
    By vectrasxi in forum Styling
    Last Post: 22nd July 2007, 18:41
  5. Debadge procedure
    By BlueRob in forum Styling
    Last Post: 28th May 2007, 23:47
https:www.vectra-c.comforumshowthread.php181169-Vectra-c-fob-re-syncing-correct-procedure-please
https:www.vectra-c.comforumshowthread.php181169-Vectra-c-fob-re-syncing-correct-procedure-please#::text=To re-sync a fob it should start working again.https:www.vectra-c.comforumshowthread.php181169-Vectra-c-fob-re-syncing-correct-procedure-please#::text=To re-sync a fob it should start working again.&text=Put key in ignition and turn to position 2.vrectra 2003 key syncvectra c remote key not working3 Buttons Remote Car Key Fob opel vectra c progtamopel vectra c key programingvectra c key fob resyncvectra C key fob issuesvectra c key fob not workingvectra c remote programmingopel vectra c sync keyhow do you reset the remote on a Vauxhall signamhow to recode vectra c keyvectra c how to syncronise acvectra c key fob battery replacementvectra c remote key programmingvauxhall vectra c 1.8 reprogramming keyhow to sync key vectra creset key vectra C opel sinronizing kayvectra c key fob programmingvectra c central locking programhoelw to pair fob with vauxhall Vectravauxhall vectra 2006 car key fob reprogramm
