Results 1 to 10 of 11
Thread: Meriva wont start
    Aug 2011
    Dudley
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTI 150BHP
    Mileage : 170,000
    Default Meriva wont start
    Guys,
    A friends 1.6 Meriva 05 reg wont start and the following codes are displayed.
    Total number of fault codes: 5
    P1615 - Wrong Vehicle ID from Body Control Module
    (00) - Present
    P1616 - Wrong Vehicle ID from Instrument Control Module
    (00) - Present
    U2107 - CAN-Bus no Communication with Body Control Module
    (00) - Present
    P1482 - Fan Relay 2 Signal Low / Open Circuit
    (04) - Present
    P1483 - Fan Relay 3 Signal Low / Open Circuit
    (04) - Present
    Could this be a module problem or is it more likely to be a wiring connection. He did say he had noticed the rev counter dropping to zero sometimes before the problem.
    Regular Member wright8672's Avatar
    Spalding,Lincolnshire
    Vehicle : vectra
    Engine : 1.8
    are all the dash lights as normal,can the fuel pump be heard priming on turning the key and does it turn over normally but just not firing?
    Aug 2011
    Dudley
    Mileage : 170,000
    Quote Originally Posted by wright8672 View Post
    Err, dont know so I will have to find out. Assuming yes and no what would be your advice.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try different key
    bcms have problems on these
    Vehicle : vectra
    Engine : 1.8
    could be an immobiliser fault,but more likely the crank sensor.
    Aug 2011
    Dudley
    Mileage : 170,000
    There is no fault code relating to crank sensor but will get him to try his spare key if he has one.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    wonder if these suffer the bad connection on the instrument cluster as corsa C do , try tapping the dash above clocks.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by DTi Elite View Post
    There not Can-bus though are they?
    May 2012
    county durham
    Mileage : 145k
    looking at the fault codes they are similar to what appear on a corsa when it has a bad connection , worth a go
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    looks like somebody hit the 'reset' option when using a certain piece of software..
  1. car wont start? :(
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th March 2012, 12:30
  2. 2.2 dti wont start
    By Tayla in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 21:09
  3. help car wont start!!
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 03:51
  4. Wont start
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th November 2010, 19:47
  5. Car wont start - please help
    By zafira in forum Diesel Engine related
    Last Post: 6th November 2010, 14:25
meriva a P1615 P1616
dtc P1615 & 1616 Vauxhall
wrong vehicle id from body control module meriva
