Thread: Elite Cdti Alternator overcharging?
    Jul 2010
    NORTH WALES
    Default Elite Cdti Alternator overcharging?
    Vectra Elite Cdti 05 plate died last night on the wife with what appeared to be classic alternator failure signs ie lots of lights on one after the other and then power steering failure.
    Went to it this morning and trickle charged the deadish battery via big jump leads for 20 mins and drove her 5 miles home with no problems at all.
    Father in law picked up a voltmeter? (has a loop at the top which went around the maind red wire from the alternator to the battery)
    Car was charging at around 14 initially and then 19 with lights and heater on. When when revved under load was the pushing out a massive 31.5
    Before i spend on a replacement alternator i just want to check that the readings above are signs it is overcharging before looking at other possible faults.
    Thanks in anticipation
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    The hip around the wire is inductive and measuring current flow
    Use multimeter in volts mode with wires across batt terminals
    best bet take a static batt reading
    take a cranking batt reading
    take a voltage reading once running at idle
    same again with all load. Ie lights, heaters etc
    then again at 2000rpm
    then take measurements at the back of the alternator
    how do they compare to batt readings?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Clamps normally read amps don't they? Might be worth checking on that. A proper multimeter on the positive and negative terminals will show the correct voltage or failing that, if you have the standard stereo in the car you can use that to see the voltage. Hold down settings until you hear a beep, then press BC to cycle through the test menus. One of them will show the battery voltage. Should be between 13.8 and 14.4 running normally. Probably dropping a bit as things are turned on, then it'll catch up. If it was really kicking out 31.5 volts, you'd be blowing the thing up. The battery wouldn't take it, nor would any of the electrics. Be popping fuses everywhere.
    EDIT - if you wanna have a laugh with the clamps, turn the steering wheel from lock to lock and watch. Serious current!
    Jul 2010
    NORTH WALES
    Going to take it to an auto electricians Monday to get everything tested, father in law is great mechanic but electrics not his thing to be honest. Have to rely on my RX8 now until next week, talk about irony
    Is the power steering pump electric powered then i take it given it wouldnt work last night, seems a tad scary given the engine is till powering the car
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Power steering is hydro electric. Electrics powering the pump. Something isn't right and I'd bet it is the alternator just failing but not overcharging. One of the first things to go when the alternator fails is the power steering because it sucks the most current.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    If he's a mechanic then he knows where connections are
    and carrys out the above tests then theirs a good chance of finding the fault without paying out any cash
  1. 120 cdti alternator?
    By Big Sig in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2012, 01:34
  2. V6 3.0 cdti alternator
    By iwtand in forum Engine & Drivetrain
    Last Post: 7th September 2011, 23:47
  3. Possible ALTERNATOR on the CDTI 150 -HELP!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 25th February 2010, 16:03
  4. 1.9 cdti alternator help
    By in7ox in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2009, 19:26
https:www.vectra-c.comforumshowthread.php181160-Elite-Cdti-Alternator-overcharging
vectra 1.9 cdti alternator running voltage
3.0cdti alternator not charging
