As tittle all my brakes are rattling is there any temp way to stop them really annoying now
Have u tried turned the music up ? LOl
Are pads genuine or aftermarket ?
That's what I do but people look as it drives by due to the rattles getting worse. There aftermarket and new pads are a no go at the moment
hopefully you remembered to put the anti-rattle clips back on ??
good time for big brake upgrade
How about som copper grease on the BACK of the pads?
Ah no not got any grease on might have to put some on
Always used to put a smear on the backs, even if they had anti-squeal shims. Sometime you can buy "Brake" grease or "Rubber" grease, it does the same.
Grease the rubber guiding sleeves, and if the rattle comes back after a while, consider changing them, as it means they just got loose : dirt and water gets in and the grease gets washed off.
Sliding Sleeves, Caliper : GM 90510227 / Vauxhall 16 05 905 - Set of 2
Front and rear, any discs diameters all the same. Sold by pairs.
