Results 1 to 3 of 3
Thread: Wet Carpet after nearly 3 months of clrearing scuttle drain.
    London
    Default Wet Carpet after nearly 3 months of clrearing scuttle drain.
    I have removed and cleared the scuttle drain (preface 53 reg) and after nearly 3 months now and I am still finding the passenger rear carpet soaked but only in the foam right below the area under passenger seat. (not as bad as it used to be when scuttle was blocked) Anyone know what is the normal timeframe for drying out process, as the foam is quite thick so do I need to take carpets off and let them dry or can I wait longer? Or worse is there another leak but I have checked the front and back of car and all appears to be fine and changed pollen filter.
    (btw the water is below the carpet now is only inside the foam and can only be felt if I tuck hand under the foam area on the passenger side feels really soaky)
    Any help would be appreicated.
    any help would be appreicated. thanks
    London
    hi, cant anyone give any advise. surely im not the only one with this problem ! any anyone else check thorougly ?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Maybe another leak
  1. Finding and cleaning scuttle drain channel
    By Robsey in forum Bodywork & Interior
    Last Post: 4th January 2013, 21:04
  2. Water in passanger footwell and not the scuttle drain???????
    By dannydoncaster in forum Engine & Drivetrain
    Last Post: 17th June 2012, 12:49
  3. Scuttle removal
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2011, 09:09
  4. Scuttle Plate
    By Aaron1970 in forum Bodywork & Interior
    Last Post: 5th June 2009, 23:40
vauxhall vectra scuttle drain
