Thread: Hand Brake Needs Tightend
    Aug 2010
    London
    Default Hand Brake Needs Tightend
    HI.
    I have a 2003 vectra c 1.8. I am just wondering what the best method to adjust my hand brake would be. I need to make it tighter.
    I know the handbrake is a self adjusting one however the cable seems to be to slack and even when i reset the adjuster inside the car, it goes right back.
    What is the simplest way to tighten the handbrake cable??
    Please help as i have my MOT very soon
    Engine : 1.9 CDTi
    Tie a knot in it or replace the cable
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    ^^^^^^ what said, need to replace it when its stretched that much.
    Aug 2010
    London
    Default http://www.vectra-c.com/forum/forum.php
    Urm, I could pull the cables at each of the wheels a bit tighter perhaps??
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    new cable is about £40 and an hour n halfs work on a pair of stands
    Aug 2010
    London
    There must be some way to tighten the cable. cant need replacing straight away.
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Have you checked rear calipers are working properly
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Self adjusting, and you've reset the adjuster. I'm afraid it's new cable time
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    I actually feared it would get loose after fitting new brakes (used 314/292 mm calipers, brand new discs and pads), but it actually self-tightened over time.
    Try to pull the handbrake level like crazy, and next time it should get just as tight, pulling it a bit less far.
    If it doesn't, then you'll have to change the whole set, unfortunately.
    There was also a topic about adjusting or resetting the mecanism here, maybe it could help you :
    http://www.vectra-c.com/forum/showth...ndbrake-adjust
  1. Hand Brake
    By crispy007 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 18:05
  2. hand brake travel
    By big tee in forum Suspension, Wheels & Brakes
    Last Post: 27th September 2011, 12:58
  3. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
where is the hand brake adjuster on the vauxhall vectra c 1.8 2008
