Thread: what does code 95 mean o the dash?
    Regular Member mike.'s Avatar
    Oct 2012
    peterborough
    Trim : SRi NAV
    Engine : 1.9 CDTi 120
    Default what does code 95 mean o the dash?
    as title,a friend of mine has just text me and said that has appeared on his dash?whats it mean?
    cheers
    Oct 2012
    peterborough
    Trim : SRi NAV
    apparently it means service airbag i just been told.
    Regular Member 0011728's Avatar
    Nov 2007
    Vehicle : Vectra C & Insignia
    Trim : Elite & Elite Nav
    Engine : 1.9 cdti /2ltr Turbo
    Year : 09 64
    Yep, airbag it is. Here is the full list.
    Thought this might help people who dont have the full list of error codes in their manuals. Some seem to be missing from this i.e. number 10 but it could just be GM being random again!
    The vehicle messages are displayed as code numbers.
    No. Vehicle message
    1 Change engine oil
    2 No radio remote control detected, depress clutch pedal for a restart
    3 Engine coolant level low
    4 Air conditioning off
    5 Steering wheel is locked
    6 Depress brake pedal to release electrical parking brake
    7 Turn steering wheel, switch ignition off and then on
    8 Switch ignition off and then on, repeat breath test
    9 Turn steering wheel, start engine again
    11 Brake pads worn
    12 Vehicle overloaded
    13 Compressor overheated
    15 Centre high-mounted brake light failure
    16 Service brake lights
    17 Headlight levelling malfunction
    18 Left low beam failure
    19 Rear fog light failure
    20 Right low beam failure
    21 Left front sidelight failure
    22 Right front sidelight failure
    23 Reversing light failure
    24 Number plate light failure
    25 Left front turn signal failure
    26 Left rear turn signal failure
    27 Right front turn signal failure
    28 Right rear turn signal failure
    29 Check trailer brake light
    30 Check trailer reversing light
    31 Check left trailer turn signal
    32 Check right trailer turn signal
    33 Check trailer rear fog light
    34 Check trailer rear light
    35 Replace battery in radio remote control
    48 Clean side blind zone alert system
    49 Lane departure warning unavailable
    50 Activated pedestrian protection system, reset bonnet
    51 Compass unavailable
    53 Tighten fuel filler cap
    54 Water in diesel fuel filter
    56 Tyre pressure imbalance on front axle
    57 Tyre pressure imbalance on rear axle
    58 Tyres without TPMS sensors detected
    59 Open and then close driver window
    60 Open and then close front passenger window
    61 Open and then close rear left window
    62 Open and then close rear right window
    65 Theft attempted
    66 Service anti-theft alarm system
    67 Service steering wheel lock
    68 Service power steering
    69 Service suspension system
    70 Service level control system
    71 Service rear axle
    73 Service All-wheel drive system
    74 Service AFL
    75 Service air conditioning
    76 Service side blind zone alert system
    77 Service lane departure warning
    78 Service pedestrian protection system
    79 Top up engine oil
    80 Change transmission fluid
    81 Service transmission
    82 Change engine oil soon
    83 Service adaptive cruise control
    84 Engine power is reduced
    95 Service airbag
    Oct 2012
    peterborough
    Trim : SRi NAV
    ah mate thats spot on!will get a printout of that.very handy.
    cheers
  1. Facelift Dash Trim on a Pre face dash?
    By jordib in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 22:15
  2. Wiring - Dash loom/cables behind whole Dash
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2013, 10:49
  3. mil control circuit malfunction code PO650 ( no dash warning light on car)
    By richiem in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 23:08
  4. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  5. Paint code for silver dash pieces/Irmy Knob Etc...
    By Leemarksmith in forum Styling
    Last Post: 23rd June 2010, 21:15
https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash
https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=apparently it means service airbag i just been told.&text=Yep airbag it is. error codes in their manuals.
https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=apparently it means service airbag i just been told.&text=Yep airbag it is.https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=81 Service transmission 95 Service airbaghttps:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=-View Profile&text=apparently vectra-c.https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=83 Service adaptive cruise control 95 Service airbaghttps:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=82 Change engine oil soon 95 Service airbaghttps:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=vectra-c.- comforumshowthread. comforumshowthread.https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=vectra-c.- comforumshowthread. manuals. https:www.https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=mike. -View Profile&text=apparently it means service airbag i just been told.&text=Yep airbag it is.vauxhall mokka code 95https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=apparently it means service airbag i just been told.https:www.vectra-c.comforumshowthread.php181104-what-does-code-95-mean-o-the-dash#::text=whats it mean&text=mike. -View Profile&text=apparently it means service airbag i just been told.
