Thread: Abs and Traction Control warning lights on in 2002 Vectra C 2.0dti
    Apr 2012
    Donegal, Ireland
    Default Abs and Traction Control warning lights on in 2002 Vectra C 2.0dti
    As above. I'm doing a bit of work on a friends car and both these lights are on in the dash. She said that the plug for the abs sensor in the front drivers arch had dislodged and trailed along the ground. She just wants the lights out to pass the test and doesn't care if it works or not.
    My question is if i splice the wire together will it put out both lights or just the abs?
    Any help much appreciated
    Rory
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    You will have to disconnect the ABS Pump connector and reconnect once you've done the work.
    I had a duff connection in the drivers front wheelarch and repaired it, but the light wouldn't go out til i tried the above
    Apr 2012
    Donegal, Ireland
    Quote Originally Posted by MrDerv View Post
    I have a code reader that can delete the codes from the euu and im hoping that will do the same job after I've spliced it. Does the traction control work off the same connection?
    Nov 2011
    Yes, the traction control runs from the abs pump, but clearing the codes might not turn off the light. I tried clearing it twice but the only thing that turned out the light was to pull the abs pump plug for 5 mins
    Administrator plasma's Avatar
    On the Forum
    565 Post(s)
    Engine : 150
    Mileage : 74000
    unless the fault has been rectified the code will not go away, it isnt a matter of open or short circuit but a signal which goes up the cable
  1. ABS & Traction control lights on?
    By keithsimmo in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2013, 20:17
  2. traction control and abs lights on....?
    By jungle in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2010, 21:22
  3. A.b.s/traction control warning lights
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2009, 00:08
  4. Traction Control Warning Light
    By oldmanmille in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2009, 22:16
  5. a.b.s. traction control lights
    By simplesi in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 11:40
vectra abs and traction control light on
