Results 1 to 3 of 3
Thread: Faulty door mirror
    Nov 2012
    Essex
    Default Faulty door mirror
    The mirror on my drivers door wont move up/down with the switch. It'll go left/right but not up down. Should I be thinking faulty motor or switch? Or something else?
    Also, the deicer function doesn't work on that mirror. It does on the passenger side. I think there's a small heating element built into the lens? So I should buy a new lens.
    Any helpful suggestions gratefully received
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Remove and clean the switch,them remove your mirror and the two spade connectors from the back of the mirror,clean the connexions then replace,I had the problem with the heating element not working did this and its all sorted and working again
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    If your left mirror works then i'd say it's the wiring/ motor.
  1. door mirror
    By dustydes in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 14:42
  2. Wing mirror heater faulty
    By tommyk999 in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2009, 19:12
  3. faulty wing mirror
    By colinjames69 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2007, 01:05
