Anyone tried or have any input on the Toyosport decat pipe: http://www.ebay.co.uk/itm/VAUXHALL-A...item5d33bbb857
I was looking at it but does not say zafira but I'm sure astra is the same
Hi Lee i bought one off these from a member on here , at the time i did not know that the one i bought was for the dpf model , but was not a big problem as it just needed a bit off extra pipe when i had it fitted at an exhaust place . the car now has a bit more rumble than before , and have noticed that the exhaust pipes blacken more.
I have something similar fitted to my Vectra C 1.9 150 CDTi, improves flow and sound!
Mind you I removed the main cat and fitted a straight through exhaust to single silencer at the back.
Best bet is to get this along with a full exhaust removing the DPF,get a map with deletes the DPF and eGR along with a perfomanc map.
COST
precat pipe £80
Staight through exhaust £275
Remap £220
Anyone else fitted one? If they are a decent fit then ill have one![]()
A're these to remove the front cat by the turbo am thinking getting that cat out and leave the centre one in with no rear boxes sure I will get a nice sound on cdti then
John paul hb has the same one fitted to his after i had mine done . fit is great ( just the one o got was the wrong size as said was for the dpf model , just get the right one and bolt on . ( no welding needed )
ive got a twin box mij system on mine , no center box and the decat pipe taken out and that one added , and great noise when you hit the funn pedal , but nice and quiet when just driving normal /.
