Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: y30dt won't start....
  1. #21
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by martyngell View Post
    Does size matter???
    Of course it does. Why would we drive a 3.0 if it didn't haha
    Cheers for the tip mate. I'll try to get my hands on a syringe.
  2. #22
    Sep 2010
    norfolk
    As a substitute???
  3. #23
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I'm a modest sort of chap, so stick with a 20.....Does size matter???
    Depends who you ask lol
    it all does same job in the end
  4. #24
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I ran out of fuel today. When re-filled it wouldn't start if my life depended on it. The belgian AA came to help and they fired it up with the start spray...oh well. Lesson learnt not to drive 60miles with the range showing 0.......
  5. #25
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Celes View Post
    As soon as my fuel light comes on I go for fuel. Because I know if runs out then they're a bar steward to get going agen
  6. #26
    Sep 2010
    norfolk
    The whole starting issue was made worse by my injectors being full of oil......not sure how that would happen. However replaced with my old set, started first time. Cue much happiness and dancing. Short lived as soon followed by a leak of nasty black stuff, looked like a mix of coolant, oil and diesel. Odd that as was a mix of coolant(leaking from EGR cooler) Oil (leaking from turbo feed from the block) and diesel (leaking from the injectro return on the rear cylinder head)..... All leaks now resolved except fro the injector. Does anybody know, other than the stealer, where i might get a suitable banjo bolt from M10x 1.25 and 30mm long under the head....not a standard size and like rocking horse manure.....
  7. #27
    Derbyshire
    Vehicle : Vectra Hatchback
    Engine : Y30DT
    Mileage : 289,000
    Martyngell, slightly off subject to start with, but I assume you must have disconnected all the high pressure fuel lines when you stripped the engine down. How did you depressurise the system as I am going to tackle an injector soon?
    Now back to subject, if a little late. There should be a marker on the crank shaft pulley. If I remember rightly when I did mine a couple of years ago the mark was full of dirt and invisable until I scrapped it. Also the mark on the casing is not easly seen with the engine in the car. I think I had to use a mirror to be sure I had it lined up.
  8. #28
    Sep 2010
    norfolk
    With regards de-pressurising...didn't! Had the fuel rail and injectors off several times and never had an issue.
  1. Why why why y30dt.....
    By martyngell in forum Y & Z30DT Specific
    Last Post: 31st May 2012, 14:04
  2. Y30DT - what's this sensor?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 1st January 2012, 18:59
  3. y30dt egr
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 08:43
  4. Y30DT again
    By Celes in forum Engine & Drivetrain
    Last Post: 7th May 2009, 14:22
