Results 1 to 10 of 28
Thread: y30dt won't start....
    Sep 2010
    norfolk
    Default y30dt won't start....
    All thoughts gratefully received....
    Head gasket went on christmas eve, and on strip down discovered 2 pistons damaged on the crowns, no bore damage so replaced. Turns over fine on the starter and by hand. BUT will not start, getting fuel through to the injectors. All fault codes cleared and no new ones on trying to start up.
    My only thought is, is it possible to set the cam timing 180 degrees out, all timing marks lined up as they should on the cam pulleys and the fuel pump, but no marks on the crank pulley to check, any thoughts anybody???
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Does it run on a start spray?
    If the top of the cylinder bore/crown was damaged it is very likely that it bent the block as it's all of aluminium. Random ideas here, not a mechanic
    Sep 2010
    norfolk
    Thanks for the thought, heads and block checked and all straight and flat. Haven't tried spray start, didn't know were to squirt it really.....oh, other than into the turbo....cold and tired, please excuse brain fade.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    When mine wouldn't start and I had to get it going we squirted the spray into the air intake just behind the front grill, we didn't have to disassemble anything. Make sure that under NO CIRCUMSTANCE you wait for the glowplug light to go off...if you do you will hear a scary bang...
    Spray directly into the intake and then turn the key to start the engine without waiting for glowplugs. Although this is not exactly advisable to use it all the time, it's fine to use it once or twice.
    Sep 2010
    norfolk
    Cheers mate, I'll give that a bash...any thoughts or experiences with the cam timing issue?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine recently went in for a cambelt change (and water pump leak) and the mechanic said the gears connecting the crankshaft and fuel pump can only go in if aligned (cambelt has to be aligned). I'm positive your cambelt is aligned properly, if it weren't I'm sure you'd hear some valves scraping the cylinders lol
    Sep 2010
    norfolk
    Given theres no unpleasant piston/valve smashing noises i think your right, was just clutching at straws really....
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It's always "clutching at straws" with this engine lol
    Good luck mate and keep us posted!
    Also, once you have drained the fuel system it can take a long time for the fuel to reach the injectors and re-prime the system
    This is quite obvious when you replace the fuel filter
    Equally, the same happens when you just loosen the cap!
    Sep 2010
    norfolk
    Thanks for that, unfortunately cranking the car over has flattened the battery. So, now on charge will try again tonight. Snow willing....must admit, I am tired of wet and cold.....
    Any thoughts on the use of "easy start", had a look on t'internet last night..... lots of conflicting opinions.
    After one costly re-build this year, would hate another so soon. Was expecting the car to last at least two weeks before it chucks its toys out again....
  1. Why why why y30dt.....
    By martyngell in forum Y & Z30DT Specific
    Last Post: 31st May 2012, 14:04
  2. Y30DT - what's this sensor?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 1st January 2012, 18:59
  3. y30dt egr
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 08:43
  4. Y30DT again
    By Celes in forum Engine & Drivetrain
    Last Post: 7th May 2009, 14:22
