Results 1 to 10 of 13
Thread: Car went on the ramp and....
    Jan 2013
    Midlands
    Default Car went on the ramp and....
    All looked really well, as mentioned new rear control arms needed, going to put some silicone on my barke lines to stop them perishing and need to bolt down the heatshield which is loose, all those hopefully will be done by the end of the day.
    BUT
    We cant for life figure out the knocking creaking knoise from the front, suspension bushes and mounts are spot on...
    I think it must be the springs moving in the cups, apparently they can be fixed with some sleeves but for the time being I am going to live with it...
    Always nice to see I havent bought a complete lemon like last time
    also have full service history up to 2010, so going to do a service once its a little warmer, saying that oil is clean as anything and all is smooth and quiet.
    Jan 2013
    Midlands
    And rear struts are Gas, not sure if this is normal or an upgrade but explain the height and firmness
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    35 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 270,000
    Mine is creaking and clattering front and rear. :-( Having had the mechanic who presented my car for its MOT in September check the suspension on a lift for me and draw a blank, my money is on anti-roll bar bushes front and rear. (I have less than one year old Meyle drop links on the front but shall replace the rears.) I'll be doing all this when I can free up some time, money and mojo. Paul
    Jan 2013
    Midlands
    I am not too worried about those but will replace them too prior to next MOT...I did them on my last mitsubishi and they were easy except for the fact the thread had gone in the drop links so had to cut them out
    Youll have to let me know how you get on with them once you have done them.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Mine has a creaking type noise that sounds like bushes/rubber, but most say that its anti roll bar rubbers, only does it when cold not when hot but that could be the heat from the engine expanding bar or rubbers.
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Radiator springs... I didnt believe it either, spray them with WD40.. my knocking stopped instantly.
    Open the bonnet, look down at the rad, at the top under the slam panel there is 1 spring each side... cake it in WD40 & try it.
    Sep 2010
    have you looked at the anti roll bar bushes?... usually a culprit
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    [QUOTE=JJ0063;1982987]Radiator springs... I didnt believe it either, spray them with WD40.. my knocking stopped instantly.
    that cured mine
    Jan 2013
    Midlands
    Thanks everyone, car wil go for upper arms next week, and will ask him to double check the ARB's we did look over them today but couldnt see anything...will try again
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    I highly suggest trying just spraying WD40 on the springs that hold the top of your rad in, I knew about them for months & just laughed when people on here suggested it. I tried it just thinking I was taking a slash in the wind but it actually worked!
  1. Ramp hire- Birkenhead
    By Critch in forum North West (RO - bonehead, ARO Woody
    Last Post: 2nd June 2012, 19:01
  2. Replies: 4
    Last Post: 24th August 2011, 20:04
  3. Garage/Ramp hire
    By russ1969 in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2011, 01:27
  4. Rent-a-ramp (DARWEN,Lancs)
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2010, 14:21
