Thread: CDTI oil circulation?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default CDTI oil circulation?
    Are there any known issues with oil pressure circulation/pump problems with the cdti (150/04rg), Every time on the first start of the day the oil seems to be a lot slower getting up & around the engine than it used to be, only noticed it recently & today took the oil filler cap off at start up & it does sound dry running for a while, Had the 04rg from new & service it every 5k or so with vx bits & only on about 78k miles so i know its looked after.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    There's not any known problems to my knowlege. Sounds like it's worn?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    does it use oil? handbook says you can use 5w40.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Its like a new car full stop!, never had to top up EVER between changes & at 78k miles it is very low miles really, engine has vx fully synth 5/30 every change & as said its done every 5k or so, no oil leaks no usage full stop & engine looks & drives as new.
    Wirral
    5 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Stick a manual oil pressure gauge in where the electrical one would normally go, can't for the life of me remember where it is on these engines and get someone to start it up as you watch it. I'm sure someone on here will have the oil pressures noted down somewhere.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Tried op com on it but that was after it had been started though, just said 'normal', will try again tomoz on first start up see if its any different.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by the-wizard View Post
    Still having the noise on first start up & today after starting up i quickly removed oil filler cap & can still hear a dry sqeeking till oil lubricates things!, if anyone out there with a 150 could wip there oil cap off on first start up & have a listen & any feedback would be greatfull.
  1. 3.0 cdti clutch. Fits in 1.9 cdti?
    By Zampus in forum Engine & Drivetrain
    Last Post: 16th February 2010, 14:22
  2. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
