Thread: Rear caliper rebuilds
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Rear caliper rebuilds
    Anyone undertaken this on a wind in caliper. Is there anything to look out for. I've done normal calipers before but never the wind in type.
    Normally i'd just buy recon calipers but I got 2 292 calipers and carrier for nothing a couple of years ago but one of them is seized. It just so happens that the IS3 now needs new rear pads so I was going to refurb the 292 calipers and fit the 292 discs and pads as they cost the same as the 278s.
    Does the back plate on the facelift need cut for the 292 calipers?
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    38 Post(s)
    Engine : 1.9 DTH
    U either cut it or replace for one designed for vented discs.... Iirc they are 11£ odd from Vauxhall , bad news rear hubs have to come out , as for caliper pop dust cover off, unscrew piston replace inner seal u can use 278 mm piston as they same size
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers Seb, what part of the cover needs cut. Is it for the caliper or the disc?
    38 Post(s)
    Engine : 1.9 DTH
    Is for discs mate , I've changed them for vented ones rear hubs are 4 bolts only u can cut off the lip I would think to accommodate vented discs
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers again bud, I'll just change the back plate too then. I'm saving about 100 quid by rebuilding the calipers myself anyway
    First caliper stripped today and it appears it was the handbrake mech sticking on it. I've freed everything off so it should be ok. Gonna do the other one before I think about ordering seals though
  1. rear caliper
    By roverjay in forum Engine & Drivetrain
    Last Post: 5th January 2013, 17:20
  2. Rear caliper
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 23rd September 2012, 09:42
