Results 1 to 10 of 20
Thread: CD70 external in
    Regular Member mjhayward's Avatar
    Oxon
    Default CD70 external in
    does anyone know if the CD70 has an external in ? if so is it line level, can a Parrot CK3000EVO be conected to it to avoid needing a harness adaptor ?
    Thank's
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    the cd70 has an external line in for phone; do a search on PARROT and all your questions will be answered -there is even a how to or go directly to this superthread
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by sig63 View Post
    @ SuperThread
    It certainly does and can be done actually fairly easily without a harness once you know how Mine now works a treat (NB If you use the diagram in the thread that shows Line(+)? and Line(-)? These are Line + and - but are reversed ... I'll edit the piccy at some point )
    Dave
    Oxon
    Hi
    Am I looking in the wrong place cos I can't see any line out wires on my Parrot CK3000EVO
    Any help would be apreciated.
    Jul 2006
    Cheshire
    Quote Originally Posted by mjhayward View Post
    Hi
    I take it the unit isn't fitted to your car yet? You should have a push button unit, a mic and lead, a blue conrol box and a wiring harness. The wiring harness will have lots of wires but some should have labels on and you should find the following that need to be used:
    Yellow Mute wire
    long thin Black Line out -
    long thin Red Line Out +
    Red Constant 12v Live
    Orange Ignition LIve 12v
    Black Earth
    Dave
    Jul 2006
    Cheshire
    This page then shows connections to the head unit:
    http://forum.vectra-c.com/showthread...=parrot+fitted
    Oxon
    hi
    had a look but there are only cables going to the ISO plugs for speakers, can't see any unused ones. Any ideas??????
    Jul 2006
    Cheshire
    Can you post up a pictrure of your Loom?
    Dave
    Oxon
    Hi
    Link to online instruction book.
    http://www.parrot.biz/usa/support/do...ide_zone_a.pdf
    Thank's for taking so much time!
    Jul 2006
    Cheshire
    Hmmmmm!!! It's different to the 3200LS ... I would guess your best bet would be to:
    Power Cable
    Connect Orange to Cig Lighter Live
    Connect Black to Earth on back of Head Unit
    Connect Red to Live on Back of Head Unit
    Mute Lead
    Connect Yellow Mute Wire to Mute in pin show below
    Plug A - ie to Car Stereo
    Connect to matching pins on back of Head Unit Quadblock (shown on Diagram Below) ... however I'm unsure from the Parrot diagram which sides + and which is -
    I would probably run pieces of wire from the Iso block to the back of the Quadlock connector but you would need to ensure the connections are solid as it's quite tight when you push the head unit home ... a Sound on Top lead may be a less painful option ... depends how confident you feel with wiring as to whether you feel £20 is worth it.
    Dave
  1. External Lighting
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2012, 09:15
  2. Cd70 external gps aerial
    By simonwrx in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 22:29
  3. V6 external oil coolers
    By Leigh16v in forum Tuning
    Last Post: 10th January 2010, 16:33
  4. CD70 External In - Video
    By daba in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2009, 17:59
  5. Tom Tom external antena
    By SteveH in forum General Chat
    Last Post: 16th August 2007, 21:10
vectra display external in
extern in cd70
vdo cd70 pinout
opel vectra c extern in
opel vectra c cd70 quadlock pinbelegung
Cd70 quadlock
opel cd70 navi line out
