No remove the light unit then you can cut in and solder to it etc... Got one in bits in my boot if need a pic, will post tomo, or there's a thread I did ages ago showing how I did it, but good luck finding it with the new search function...
Whats the possibility of adding two 5-10w bulbs for footwell lights onto the currant circuit without damaging bcm? Id prefer halogen bulbs to led, seem to bright for me. Thanks
You'll get away with a couple if extra bulbs too, no prob...
Cheers matey. Very useful, many thanks,
Woody
as stated it is negative dimed so u will need it from the lights them selfs i just stuck the wire into the bulb fittings, and if u want them to go off after a while when the bulbs go out u will need the positive from there as well, as i found out lol but its leds so should be a problem if i leave the light on
the white plastic circles, they twist out.
