Results 1 to 10 of 28
Thread: Which wires on interior light?
    Nov 2010
    Maidstone
    Default Which wires on interior light?
    Does anyone know which of the 4 wires on the interior light unit is positive and negative? Just looking to tap onto for some footwell lighting. Thanks
    Regular Member glasgowdarren's Avatar
    glasgow
    Tap into the bulb holders. Just connect to the metal part of the bulb holder with any speaker wire, then just feed it around frame to the foot well. This is how i did it and looks great.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Quote Originally Posted by signum_rob View Post
    Could do with knowing myself to take feed for light up sun visors
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Do it properly on the wires, much neater and easier to remove light in future if put a connector up there... Brown/white & brown are the ones you need.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Quote Originally Posted by patch22 View Post
    The sun visor plugs were already in the roof on mine
    Jun 2011
    Vehicle : vectra
    Year : .....
    Quote Originally Posted by Mr Owens View Post
    Had a half hearted look at finding them,but didn't drop the roof lining very much just slid a hand in and had a feel around were they anywhere near the holes where the visors fit into the roof
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    You don't say what year yours is but I think they're all pretty much the same:-
    Brown : +12v (via BCM)
    Grey : LED dimming signal
    Blue/Red : Ground
    Brown/White : interior lamp control from BCM (in effect ground but supplies the slow fade effect by varying the voltage)
    So as Lee said you want the brown and brown/white if you want them to fade with the interior light.
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    They were taped with fabric tape to the roof linning
    Jun 2011
    Vehicle : vectra
    Year : .....
    Ah right i was fishing around on the under side of the roof itself theres still hope then lol cheers for that Mr Owens
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    If you pop off the A pillar and grab handle you can fold it back enough to see if you have the plugs, they actually tape them only a few inch away from the hole...
  1. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  2. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  3. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  4. fog light wires
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2011, 18:28
  5. Feeding wires from engine bay to interior - driver side
    By Vid in forum Bodywork & Interior
    Last Post: 6th August 2008, 20:52
