Thread: Mpg 1.8 VVT Estate
    Feb 2013
    Yorkshire
    Trim : SRI
    Engine : 1.8 VVT
    Year : 07
    Default Mpg 1.8 VVT Estate
    Hi Guys and girls,
    I'm new to the forum, forgive me if this has been discussed before.
    I am getting a steady 29 mpg average no matter what i do and how quick i drive it does not change, before i start changing everything to see if it helps is there a common thing i can do eg: spark plugs, cleaning sensors? thanks in advance
    Simon
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Hello Simon, i have a 1.8vvt and i get better mpg than that,on a run i get 40plus and about 33 round the doors,When was it last serviced.if your not sure i would get it done,good oil and all the filters--easy job.Change the plugs and just give the car a good going over,i'm always on with mine-keeping it in good nick--and try and use genuine parts,hope this helps Dave--
    Feb 2013
    Yorkshire
    Trim : SRI
    Engine : 1.8 VVT
    Year : 07
    Hi Dave,
    Thank's for the reply, only done about 9k since i got it and not sure when it was done, so will give it a full service are the genuine plugs the best to use?
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Hello Simon, thats what i use--dirt cheap on evilbay--otherwise you can give your local dealer a call-i see you are in yorkshire and i buy my parts from evans halshaw in Leeds,lad called Adrian Close on 01132430131 or 01132439911 ask for parts dept- he is a good lad and will sort you out with some discount,hope this helps--he will want your reg number-----Dave
    Dec 2011
    Seaham
    Also check for brakes binding, jack each corner up and check the wheels move freely.
    I have the 1.8VVT saloon and easily get over 35 mpg
    Regular Member bigstu31's Avatar
    May 2012
    Southampton ish
    Vehicle : vectra
    Trim : Sri
    Engine : 1.8 vvti
    Mileage : 64000
    Sorry to jump on this, i agree with the above but have u tried resetting the mpg counter 1st and starting from zero as i had same prob when i got my vectra it never changed and it wasn't till i did this that anything changed.. Once you have selected mpg on trip just hold down left directional changer on steering wheel then away you go and see if this solves your problem before throwing money at service items.
  1. A new Vec estate to replace my Vec B estate
    Last Post: 3rd March 2011, 20:54
  2. Vectra Estate Voted Top Used Estate in What Car 2010
    By keefy*2010 in forum General Chat
    Last Post: 22nd October 2010, 15:54
  3. will vxr estate fit 150 cdti estate?
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2009, 20:06
  4. SWAP Estate VXR for Estate 1.9. CDTI 150?
    By In a states in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2008, 21:20
vectra c estate 1.8 vvt
