Thread: Clean throttle. Body
    Jan 2013
    yorkshire
    Default Clean throttle. Body
    What's best way to clean throttle. Body on vectra c 1.8. I'm getting. A few fault codes 1525 1550 1526 0100 I'm hoping these might clear when it's cleaned. I went today and bought some card/choke cleaner. Do I have to remove. It from engine email 1st?? Cheers
    Jan 2013
    yorkshire
    remove it from engine 1st. That's what it's meant to say
    Cornwall
    I dont know the vectra C 1.8 engine but I have cleaned the throttle bodies on Vecta B's and Corsa's as follows. Remove air cleaner or ducts, Turn on ignition but dont start engine, Get someone to sit in car with their foot on the throttle pedal so that the throttle valve opens, Spray in Carb cleaner and brush around body with a tooth brush. Replace Air cleaner and start engine.
    Jan 2013
    yorkshire
    Thx cliff. I'll try that in morning
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    You need to take it off the car and do it properly.
    There is a 1mm bore that will be blocked.
    Take off Air intake pipe, disconnect wiring plug, disconnect coolant hoses x 2, remove torx bolts x 4 and lift off. be careful not to damage gasket or renew.
    Clean with carb cleaner.
    Refitting is reversal of removal
    Jan 2013
    Midlands
    I did mine on my 2.2, just took the air pipe off, then the bolts holding the throttle body down, carb cleaner and cleared the pipe everyone mentions, mine wasnt very dirty and didnt change anything on the car, 77k down
  1. How to clean the throttle body of CDTi 1.9?
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2011, 13:03
  2. egr / throttle body clean at 45K
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 16:23
  3. 2.2 dti clean throttle body
    By tomo610 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 13:36
  4. DTI Throttle Body Clean
    By si_hoss in forum Engine & Drivetrain
    Last Post: 7th July 2010, 13:37
vectra c 1.8 throttle body cleaning
vauxhall vectra c throttle body clean
vectra 1.8 2002 throttle body cleaning
opel vectra c clean throttle body -fixya
z19dth throttle body cleaning
how to remove vectra b dti throttle body
vectra c 1.8 engine air breather modification
clean vectra c 2.2 direct throttle bodyVectra c 2.2 throttlevectra c 1.6 throttle body locationvectra z18xer throttle bodyvectra 1.9 cdti egr throttle body cleanvectra c throttle bodyhow to clean carb vecttra bcleaning vectra c 2.2 throttle controlvectra c trotle body reparir2008 vectra c 1.6 idle surgevauxhall vectra c 2.2 direct injection removing throttle housingz28net throttle body vleaningvectra c clean throttle body 1mmcleaning vauxhall insignia 1.8 throttlevectra c throttle body clickingvectra c 1.8 faulty throttle bodythrottle body location vectra c 1.8
