Thread: Signum Design lowering question
    Aug 2010
    Cumbria
    Default Signum Design lowering question
    Hi,
    I have a Signum Design 2.0T and am wanting to lower the car but keep the standard shocks at the moment. I have looked through threads and it seems the Design is already 15mm lower than standard so a 30mm lowering kit will only drop it 15mm? I presume this would not look much different? Could I drop the car on 40mm springs while still keeping the standard shocks?
    Regular Member Learch's Avatar
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    You should be fine lowering that much on standard shocks, just might feel abit stiff as there won't be as much travel on them with them being under more compression
    Apr 2011
    Las Vegas
    I will have a set of year old eibachs for sale soon for the signum if your after some
    Aug 2010
    Cumbria
    Cool, will they fit pre facelift 2.0t?
    Apr 2011
    Las Vegas
    I don't see why not, mines a 1.9 CDTI. The rears will be the same, you might have to check about front axel weights, I went for the lighter fronts as there are two types.
  1. Lowering Question?
    By Del101 in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2013, 18:28
  2. lowering question
    By davidmcd2002 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 15:32
  3. lowering question
    By MSharkey in forum Styling
    Last Post: 15th October 2009, 11:22
  4. Another lowering question !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 12:34
