Results 1 to 2 of 2
Thread: Solved my Start-up Problem, How weird!
    Regular Member spikeyboi33's Avatar
    Jan 2013
    Ireland/Poland
    Vehicle : Vectra C Prefacelift.
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Thumbs up Solved my Start-up Problem, How weird!
    Ok so i posted in my EGR valve thread that i had a problem with starting up of my 2.0 Vecky when it was cold, it would crank for ages but wouldn't turn over until like the third 10 second attempt. I had a service done before the problem arised and the fuel filter was changed so i thought maybe the washer was out or the fuel filter wasn't sealed properly... Turned out that the pressure made by the fuel pump unpressurised the fuel tank causing it to suck the fuel back in when the car was off for a longer period of time. All i did was unscrew the cap and read on the internet that when the cap is fully sealed (until it starts to rattle) it should be unscrewed a slight bit until you feel it starting to give up. That's the proper way of screwing the fuel cap.
    I just wanted to share this for people who might get this type of problem as well. Surely it will save you a lot of stress
    Regular Member figjam1975's Avatar
    Apr 2012
    Aberdare
    Vehicle : Vectra Life 1.9CDTI 120
    Mileage : 146,000
    I had same problem back last year, ended up drilling a 0.5mm hole (yes I know its small lol, so take care not to snap it), straight through the middle of the filler cap. No problems after that.
    11
    Quote Originally Posted by spikeyboi33 View Post
  1. Old problem still not solved - time to try again!
    By markluk in forum Engine & Drivetrain
    Last Post: 28th December 2012, 14:40
  2. poor start solved
    By Sharks35 in forum Engine & Drivetrain
    Last Post: 29th October 2012, 22:48
  3. Power steering problem solved
    By robertgsi in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2011, 21:46
  4. problem solved
    By wullierob81 in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 18:51
  5. Knocking problem solved
    By Higgins in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2006, 15:43
