Thread: Major Oil Leak!
    Jan 2013
    Hartlepool
    Default Major Oil Leak!
    So New turbo fitted, new oil and coolant filled, injectors unplugged to prime the turbo. Cranked the engine 3 times at intervals for around 10 seconds. Got out to have a look round and a huge puddle of oil under the car to the right hand side in the sump area.
    Being well and truly fed up i cursed a lot and threw in the towel. Any ideas what it could be?
    I will be pulling it apart again tomorrow to see what I can find.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I'd have a gander underneath to see where the oil is coming from, should give you a clue
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Oil banjo bolt on top of the turbo or the the sump return underneath. Did you replace the gaskets?
    Jan 2013
    Hartlepool
    I will be under there tomorrow MrDerv
    Cont1204 I replaced the drain to sump pipe gasket and re-used the washers that came off the banjo bolt
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    It'll be one of those pipes. Feet up for the night and go and look at it with fresh eyes tomorrow. Either the bolts need doing up a bit tighter or the return isn't sitting quite flush to the turbo.
    Mine's leaking too after I changed mine.
    Jan 2013
    Hartlepool
    Would be the most likely culprit, just seems like a hell of a lot of oil (at least a litre), especially after only cranking the engine 3 times.
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. 3.2 major oil leak!
    By hagga in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2010, 22:39
  3. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  4. First major mod.....
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2009, 08:32
  5. hi need major help
    By andyg12 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th November 2008, 22:14
vectra-c
vectra major oil leak
