Thread: Front Anti Roll Bar Rubbers
    Jan 2013
    Shropshire
    Default Front Anti Roll Bar Rubbers
    Hello,
    Does anyone know if I have to drop sub frame to change front anti roll rubbers on a Vectra C 2006 1.9 150 as I have changed my front drop links and when I go over some bumps I can here it knocking.
    durham
    Trim : Leather
    No no need to drop it its fiddley but you'll do it ok.
    South east
    No, it's much simpler than dropping the subframe, just take off the wheel, follow the ARB back with your hand until you reach the bushes that hold it in place, undo the front bolt on the bush clamp, loosen the back bolt, remove the clamp, remove the rubber bush and then reverse the procedure to fit the new one.
    Jan 2013
    Shropshire
    Many thanks, cant afford to pay a garage to do an easy job.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Fiddly but is do-able without dropping the subframe. Did mine a while back, just budget a couple of hours just incase
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Heat them in a hot cup of water, makes them more pliable.
  1. Front Anti-Roll Bar New 25.2mm
    By paulhb in forum Parts for sale
    Last Post: 7th March 2010, 14:14
  2. *New* front anti roll bar 25.2mm
    By danBoy in forum Parts for sale
    Last Post: 10th February 2010, 22:44
  3. Front anti roll bar
    By Tom Tom in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2009, 18:38
  4. front anti roll bar rubbers
    By andyd in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2008, 21:33
  5. Play in front anti roll bar ? is that ok ?
    By simac in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2008, 12:43
