Thread: Vectra Fan Speed
    Regular Member dudley6623's Avatar
    Sep 2009
    skegness lincolnshire
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    Default Vectra Fan Speed
    This morning the fan in the car decided it would only work on the fastest setting and not on any of the others!! as the fan works on the fastest in hoping its not the fan itself!! so could it just be the knob switch thats at fault?
    many thanks
    Vehicle : Jaguar XF 2.2 Sport LE
    Trim : leather
    Engine : 2.2 d
    http://www.ebay.co.uk/itm/VAUXHALL-V...item1c2c697844
    Sounds like the fan speed resistor has gone, one in the link above. If you do a search on the forum for heater motor resistor you should get more info on fitting etc.
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    As above mate check your scuttle tray drain isnt blocked aswell as this is usually what is causing you the problems an it will just happen again and again it thats the case
    13 Post(s)
    Quote Originally Posted by Rapala View Post
    You can fix it yourself for pennies.
    http://www.vectra-c.com/forum/showthread.php?134248
    http://www.maplin.co.uk/thermal-fuses-470 - you want the RA23A one
    Sep 2009
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    89p each very cheap!! altho out of stock for 30 days and to drive to my nearest store would cost more in petrol that buyin a complete new resistor. is this the same fuse http://www.ebay.co.uk/itm/BEKO-FLAVE...item3cce4dc7db
    many thanks
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Mine broke the same only number 4 would only work I bought a resistor pack at Vauxhall for 30pounds but you can buy them on eBay cheaper I did a poll on this
    If you go to the search part click on advanced and type poll scuttle tray you will find more info there
    Hope this helps
    13 Post(s)
    Quote Originally Posted by dudley6623 View Post
    Well it's a RA23A rated one.
    Just found this using a google search - mentions the Flavel Oven and using the MAPLIN part no:RA23A thermal fuse. http://www.howtomendit.com/answers.php?id=362698
    Sep 2009
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    yep ya right it mentions the same fuse!! going order it and give it a try.
    thanks for googleing for me
  1. Vectra - siggy , top speed
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2012, 11:52
  2. Vectra 6 Speed Gearbox
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2009, 18:58
  3. Vectra C 6 Speed Gearbox
    By brianrh in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2007, 18:31
