Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Battery not holding charge
  1. #11
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    33 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Tricky because access is difficult in much of the car. I'd probably try the fuse boxes first. It'd be relatively easy to remove one side of a fuse and stick a multimeter on it to check for any quiescent current draw. I guess a voltage across the fuse would also suggest that there was some current through it. The trouble would be that some circuits, if you interrupt them, might operate in a different mode afterwards. Not really sure on how to test circuits in this way. Someone will be along... Paul
  2. #12
    Nov 2009
    Warwickshire
    Quote Originally Posted by Critch View Post
    Just switch multimeter into amps and put it in series with batt this will confirm if theirs any parasitic drain
    Follow advice from Critch. Max parasitic drain should be 50mvolts.
  3. #13
    33 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    ... But not the source of the current drain. Paul
  4. #14
    Dec 2012
    Birmingham
    Could it be caused when the cam chain guide broke and the engine stalled after the inlet valves met pistons?
  5. #15
    33 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    I don't see how that could have caused an electrical fault resulting in a current drain. Paul
  6. #16
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    If the battery shows a normal voltage whilst left off the car it could still be damaged as its the battery's capacity to deliver the required current that is important. Once it's connected to the car if the battery is faulty and is asked to deliver a current that it has trouble doing it can kill it and the voltage will also drop.
    The battery may or may not be faulty but I'm saying that just because its ok off the car dosent mean its ok.
    As already said you can carry out a battery load test with multimeter, this is carried out by placing the multimeter in line from the battery terminal and the load on the battery will show on the multimeter. You can then switch things on and off to try and find a culprit if there is one. It maybe ok until you lock the car for instance. Or closing the boot may not show a drop in which case the boot light is staying on.
    Regards
  1. Holding back
    By obews in forum Engine & Drivetrain
    Last Post: 29th December 2012, 10:22
  2. Battery Has charge, Car won't start.
    By Vectra_C_Chris in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2010, 10:20
  3. battery wont charge!!
    By manghan in forum Engine & Drivetrain
    Last Post: 28th March 2010, 11:48
  4. battery charge light
    By taxidriver50005 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2008, 15:53
  5. Just holding my hands up
    By Ben H in forum Billing 2006 8/9th July
    Last Post: 2nd July 2006, 14:42
boot light parasitic drain in vectra zc 3.2v6
