Results 1 to 10 of 16
Thread: Battery not holding charge
    Dec 2012
    Birmingham
    Unhappy Battery not holding charge
    Ok so I've just finished fitting new inlet valves, new head gasket kit, new balance chain kit, new cam chain kit, full service and new battery to my vectra c z22se.
    Now my battery is dead after just 1 night???
    I had it running yesterday for about half hour idling. Then this morning it's totally dead I think multimeter read around 7v. I just had to jump start car to get it running.
    I used a multimeter whilst idle it was around 14.22v. With engine then off it read 12.82v but with a few minutes it went down to 12.55v. I'm gonna give it a couple of hours before I check it again.
    Any ideas what could be causing this???
    cheers froggy
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    35 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 270,000
    Battery dead. Fit a new one. You won't regret it. Bosch ones are available on eBay for about £100 delivered. There is a remote chance that you have a current draw problem that is draining your battery prematurely - either an electrical fault or an alternator rectifier pack gone south. But my money would be on the battery. Halfords (used to) do a free battery health check. ;-) Paul
    Dec 2012
    Birmingham
    Ok so I left the car 2 hours and multimeter reads 12.2v. So it's dropped slightly.
    tried to start the car and it doesn't want to know. Just clicks
    Put multimeter on battery again and reads 9.8v???
    35 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 270,000
    It is an ex-battery. It has shuffled off its mortal coil. It is no more.
    Dec 2012
    Birmingham
    Brand new battery already on it.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Duff battery or something is draining it. Its possible something is shorting after all that work, but probably a duff batt. Take it back!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Sounds like the battery is duff to me too.
    Dec 2011
    Seaham
    take it to a battery dealer and get it load tested, but it does sound like its stuffed.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Just switch multimeter into amps and put it in series with batt this will confirm if theirs any parasitic drain
    Dec 2012
    Birmingham
    Last night I removed battery from car and gave it a little charge. Before I went to bed it read 12.5v in the morning it read 12.4v. At about 1pm it read about 12.38v. So don't think the battery is draining on its own.
    I had it back on the car and running, switched it off and it read 12.58v. I put the multimeter + on battery and - on ground and it read the same figure. So I think I can rule out the battery earth lead.
    Where do I start in finding the fault?
  1. Holding back
    By obews in forum Engine & Drivetrain
    Last Post: 29th December 2012, 10:22
  2. Battery Has charge, Car won't start.
    By Vectra_C_Chris in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2010, 10:20
  3. battery wont charge!!
    By manghan in forum Engine & Drivetrain
    Last Post: 28th March 2010, 11:48
  4. battery charge light
    By taxidriver50005 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2008, 15:53
  5. Just holding my hands up
    By Ben H in forum Billing 2006 8/9th July
    Last Post: 2nd July 2006, 14:42
boot light parasitic drain in vectra zc 3.2v6
https:www.vectra-c.comforumshowthread.php180846-Battery-not-holding-charge
