Thread: Oil pump change..
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Default Oil pump change..
    Starting to think more & more now that my oil pump may be knackered.
    Ticking engine, slightly noisy turbo & also had the oil light come on the other day but the dipstick is showing full.
    I need to get the oil pressure checked to be sure though.
    I'd pencilled it in to have its cambelt and water pump done in a couple of weeks anyway as its just hit 81k.
    Is it going to cost me much more to have the oil pump done at the same time, and/or is it a job I could do myself?
    I can either get a tested known good part for £45, or I'll try and find out how much they are new.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Cambelt would have to come off to do the oil pump, so would be worth doing at the same time.
    Definately worth testing the pressure first though
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Cheers.
    I've spoken to my local mechanic & he hasn't got an analogue gauge but he said in the past he's had cars come in with these symptoms & its been that the oil filter has collapsed?
    My 'INSP' light came on a week or so ago so it's due a service.. i'll try this to rule it out.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    IMO only fit a new part not worth risk of fitting second hand due to damage that could occur
    the sub gram needs dropping slightly to allow sump to be removed so allow couple of hours extra labour
  1. misfire on 1 and 4 after water pump change
    By GCusdin in forum Engine & Drivetrain
    Last Post: 18th February 2013, 18:56
  2. water pump change
    Last Post: 12th December 2012, 15:28
  3. might have to change the fuel pump.. ok to use the old cambelt?
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2011, 13:42
  4. Cambelt kit & water pump change
    By Pete1nlancs in forum Engine & Drivetrain
    Last Post: 30th July 2010, 19:07
  5. Cam Belt & Water Pump change...
    By si_sri in forum Engine & Drivetrain
    Last Post: 27th June 2010, 21:48
https:www.vectra-c.comforumshowthread.php180805-Oil-pump-change
vectra oil.pimp how much
vectra oil pump replacement
fitted new cam belt to vectra c and oil light came on
