Thread: Rattle / bounce at rear over uneven ground
    Oct 2012
    peterlee
    Default Rattle / bounce at rear over uneven ground
    Hi looking for ideas / help
    my vectra1.9 cdti sri has astrange noise , it doesnt always happen but over rough / uneven bumpy ground there is a bounce / rattle from rear ( feels n sounds like rear passenger side) it feels like rear wheel is bouncing sharply and sounds like suspension rattling .
    Car has been in to vauxhall for checks , they say no play at rear bushes, arbs etc , springs just changed , along with pads ( although spring clips for calipers missing - on order ) spare wheel secured to floor ok no movement.
    They did advise of uneven tyre wear more tread to centre with approx 4mm inner and outeredge and 6mm centre .
    Could this be causing issue ??
    Or any other ideas appreciated
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Engine : 1.9 CDTI
    Mileage : 160500
    Strange for them to say its all ok but u gettin uneven tyre wear which would mean there's something not right. Although that type of uneven wear could be under inflated tyres.
    Oct 2012
    peterlee
    They said cud of been run on under inflated tyres , only had car few months , been right wrongun !
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Rear upper control arms possibly. Follow this.
    http://www.youtube.com/watch?v=h-LF-qQY-Lc
    Thanks to our very own Merikiito.
    Regular Member grabos's Avatar
    Aug 2010
    Coventry
    if not the upper control arms then rear shocks I'd say
    Oct 2012
    peterlee
    Thanks for all help , took rear shock off it was totally knackered ! Little resistance , it compressed and released like a spring !!
    sorted now !
    thanks again
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Brake pads rattling. Grease the calipers rubber guiding sleeves, or replace them if it does it again a few months later.
  1. uneven and serrated rear tyre wear
    By veclee in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2012, 02:28
  2. Uneven Wear On Rear Brakes
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 13th September 2011, 18:39
  3. uneven tyre wear on rear
    By croado in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 19:12
  4. Bounce bounce to the sound of the springs
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2010, 13:38
  5. Uneven rear brake wear
    By Wingnut in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2009, 20:51
vectra c feels lik its bouncing
rattly astra over uneven ground
vectra spare wheel rattle
