Hi All
I know there have been many threads on this, but I've been having problems with my warning light coming on and off, sometimes it stays on for ages, other times it goes off, but everytime I stop to check my lights, the damn thing goes out!!
So after reading through some of the posts, i decided to check my rear lights, being an estate it has the push and twist fittings at the rear, but all were ok. I changed both fog and reverse bulbs, as someone said these were looking a bit dim and then I noticed my left fog wasn't working and when I looked closer (having totally missed it when I changed the bulbs) I noticed a red wire coming from the left cluster that wasn't connected anywhere, but on the right someone had cut the wire and fitted a bullet terminal connection, after a quick test I realised the red wire was for the left fog, so I made a Y piece section of wire to connect a live to both fog lamps and hey presto both rear fogs working fine and I thought I had found the fault.
For 2 days the warning never came on, but thenthe third day and it was back, on and off, on and off, really, really annoying, but all my lights work and I can't work out what it is, the only other bulb I changed was a front sidelight, but that was about 6 months ago!
What's the point of having a warning if i'm never gonna know if it's lying or not, is there anyway of disabling it or any ideas what the fault could be???
I'm guessing the towbar people are the ones that cut the wire, but until I can get trailer out of garage to hook up and check the fog, I don't really know why they would disconnect the left one.
