Results 1 to 10 of 14
Thread: Power From Cigarette Lighter
    Oct 2006
    LOUGHBOROGH
    Default Power From Cigarette Lighter
    I was using for the first time this weekend my cigarette lighter to power up a little portable tv. I could only get the power to the TV with the ignition switched on - does the Vectra not have an "aux." position to run such items or is my car faulty?
    [Ex]Admin Duncan's Avatar
    Nope, the cig lighter is only powered with the ignition on. You can wire it up so that it is permanent live - just involves taking apart a fair bit of trim/panels.
    I did it on mine. I'll see if I can find the thread.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Would be nice 'cause my son gets mad everytime I switch off the engine and his DVD falls out
    but I remember a pic of your complete interior dismantled and I hope it isn't that one
    Quote Originally Posted by sig63 View Post
    ...but I remember a pic of your complete interior dismantled and I hope it isn't that one
    Err, yep - that would be the one as I did the rear 12V socket at the same time!!
    Found the pic.....
    That was to run a permanent live from the front fuse box to the front and rear 12V sockets.
    d
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    You can call me a sissy but I don't dare to do that
    is there no other way
    Oct 2006
    LOUGHBOROGH
    Thanks , but no thanks..... not even bothered to dust off the Snap On tool kit for that one.. thanks all the same
    Oct 2006
    Glasgow
    Duncan any chance of a how to on the wiring like in your above pic, also can you tell me how to strip[ the trim down to this stage, as it will be easier to work with, and give more options for the routing for the wiring.
    Nicking Ya Dinner.
    I think there is another simpler way, correct me if i'm wrong btw.
    Get a spare acc socket, these can be a single or right up to a 6 plug one.
    Take out the glove box and cut the end that would normally plug into the ciggy socket off, run the cable through the rubber grommet behind the glove box directly to the battery, add an in line fuse to this cable as well to replace the one in the end you cut off, then it's just a case of where you want to locate the sockets, in the front it could be in the glovebox, or fitted like an old phone kit to the side of the centre console, if it's needed to run to the rear, tidy the cable away in the console and maybe mount the sockets in the bottom of the centre console bucket. hth.
    Oct 2006
    Glasgow
    is it that simple?
    Any one got a pic of this.... Not sure about butchering one of these, would it be easier just to hard wire something inside the car?
  1. cigarette lighter/ power socket removal...
    By paul.sessions in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2016, 19:06
  2. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  3. How to convert cigarette lighter to 12v power outlet in both front and rear??
    By leeoliver2011 in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2012, 10:45
  4. cigarette lighter help
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2010, 21:47
  5. Rear Cigarette Lighter - Power Supply - Help !
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2008, 17:22
vectra c centre console
insignia cigarettes lighters live wire
vectra c igarette lighter power
