I managed to get an hour checking all the boost pipes and couldnt find any leaks, there are two pipes going into a small white vacuum chamber thing that is sat on top of the radiator,I took the pipes off of it and checked by sucking and blowing through them and and checked for pressure with the engine running, both pipes had positive and negative pressure there, I then blew down and sucked on the pipe that goes down to the Turbo actuator and I could definitely hear the actuator working although when I sucked on the pipe to open the actuator it was a constant suck as if the pressure was escaping slowly....is that how it should be?
I re-removed the turbo boost pressure sensor from the inlet manifold and after 200 miles it is again covered in oil residue (wet), I am guessing if there is oil vapor in the inlet manifold then that would suggest the turbo seals are going and would another possible indicator be the cloud of smoke from cold in a morning.
It is actually boosting but the power of boost and the duration is very low, I just cant work out why if it is the turbo failing I dont have masses of smoke when its driving, just the huge cloud first thing in a morning? If you flog it to death in second and third gear then there is actually a small trail of blue smoke out of the back but other than that , nothing.
The only other thing I can think of is that when I took the egr valve off I actually split the egr into two pieces and found that the small push pin that goes into the electrical half was seized inwards,I did free this off but am now wondering if the electronics in that half of the valve are malfunctioning they may be affecting the ecu in some way.....could it be I just need a new egr valve?......what actually happens when an egr valve fails? apart from putting car in limp mode would it be able to possibly restrict the turbo in some way??
any way, enough sucking and blowing for today
and many thanks for all and any advice!
