Results 1 to 5 of 5
Thread: Gear Shift Knob Removal
    Jan 2011
    Kirkcaldy
    Default Gear Shift Knob Removal
    Does anyone know how to remove the gear shift knob from a vectra 1.8 exclusiv ? I need to replace the gaiter, and the new one is too narrow at top to go over the shift knob. Hope someone can answer, Thanks.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Just pulls off, it is possible that it has been previoustly glued on as they can fall off whilst changing gear.
    May 2011
    luton
    You need a good grip and twist and pull it or cut the gator pull it over use a good double sided tape too put it back togeva
    Aug 2009
    Bristol & Stockton on Tees
    Mine fell off recently whilst changing gear, so it shouldn't take too much effort.
    May 2009
    South West
    Quote Originally Posted by Pete Elite View Post
    Dont you believe it! Mine came off in the same way, so poped it back on and gave it a tap on the top to keep it in place.... Got home and thinking it would just pop back off, not a chance! It was not coming off for love nor money!!
    It eventually popped off about 18 months later. Do a search mate, lots of posts about trying to remove yr knob
  1. vectra c sri gear knob removal
    By 1590gilbert in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2012, 10:26
  2. Gear Knob Removal
    By pompey-pimp in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2012, 13:05
  3. Gear Knob Removal
    By Tam80 in forum Bodywork & Interior
    Last Post: 26th March 2011, 20:55
  4. Removal of gear knob
    By Cheekychris1967 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th June 2010, 09:21
vectra c gear knob removal
vectra c gear knob replacement
how to change gear stick knob on vectra
how tonput gearbknob back on vectra exclusiv 2007replacement vectra gear knobvectra gear shifter removehow to remove vectra gear stickopel shift knob removalopel vectra c shift knob replacementremoving gear knob vectra cvectra c remove gear knobvectra c gearshifter knob changehow too replace vauxhall vectra knobopel vectra c gear shift knobvectra c gearstick gaiter replacementremove vectra c gear knobhow to change vectra c gear knobvauxhall vectra c change shiftre knobhow to remove vectra c gear knobvectra c gear shift changeopel vectra c gear shifthow to replace gear knob vauxhall vectra exclusivreplace signum gear gatorvauxhall shift knob replacementopel vectra c shift knob
