Thread: major clutch problems - bled to death still the same
    Mar 2011
    Glasgow
    Default major clutch problems - bled to death still the same
    ive done a new clutch and made sure it's exactly the m32 gearbox parts ive used as my box is m32 double checked the reciepts all state for m32 gearbox
    ive bled the clutch and contiously kept it topped up to the brim after each bleed session, the nipple is practically rounded now
    however ive also used an easy bleeder which showed air bubbles before and now it is clear with fluid no bubbles at all, tightend the nipple back up
    clkutch feels the same as last night very soft and only feels tight as the peddle reaches the bottom however this is the biting point (really forcing my leg down) and if im lucky i can barely get it into 1st or reverse gear
    im all out of ideas
    can anyone assist?
    i followed the how2 and the clutch springs were very low like this picture (whereas they are normally raised much higher when you buy the spring on its own) it was a luk clutch kit, and the spring mechanism hadn't been altered at all
    Mar 2011
    Glasgow
    my gearbox is defo the m32 as seen in this pic
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Nice toolbox
    I have replied to your PM
    Mar 2011
    Glasgow
    thanks xp, the toolbox isn't mine, i have 4 halfords boxes, thats judt a pic i found off ebay to show my gearbox as m32 (top mount is different on m32) and mine is defo m32, checked parts again on reciept defo m32 gearbox parts
  1. CDTI 1.9 150 - Major Problems, Help!
    By SamT in forum Engine & Drivetrain
    Last Post: 16th February 2011, 15:42
  2. 2.0T Major Problems!
    By cold-chilli in forum Engine & Drivetrain
    Last Post: 24th March 2010, 17:45
  3. Anyone bled the clutch on. (3.2)
    By lee866 in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 14:54
  4. Windscreen - MAJOR problems
    By RobW in forum Bodywork & Interior
    Last Post: 12th November 2009, 01:13
  5. No power after major problems
    By adam3682 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th August 2009, 15:16
