Results 1 to 10 of 13
Thread: ebay catch can ....... baffeled
    Jan 2013
    rosyth
    Vehicle : vectra
    Trim : sri
    Engine : cdti 150 auto
    Default ebay catch can ....... baffeled
    So after seeing one on here and reading of the benefits of not having oil pumped back into the intake and mixing with egr soot I decided to get myself one
    (plenty of other guides on how to do this on other forums)
    Started off with a eBay non baffled catch tank
    Stripped it down
    Got myself a 10mm od piece off pipe and gave it a slight bend so it would fit into the inlet and clear the walls of the tank
    Then cut notches out off it so the pipe can still breath as it fills with oil
    Next I got a mesh folder from homebase for a fiver , and cut out 3 rings with hole for intake to make a filter for the top outlet
    Then I filled it with the baffle material , for this I used stainless steel scouring balls which can be stretched out yet won't break up . One went around the pipe the other 3 packed the can. The pads were a quid
    That pic had 3 pads in the fourth went in to completely fill it and 're attached the bottom , job done
    Any comments on it or surgestions off anthing I've not thought off are welcomed . I will not be venting to atmosphere but back into intake with a hell of a lot less oil
    Jan 2013
    rosyth
    Vehicle : vectra
    Trim : sri
    Maybe should of put this in the how 2 section , ooops
    Jan 2013
    rosyth
    Vehicle : vectra
    Trim : sri
    Finally got around to fitting this today, didn't take long and happy with the results
    Made a bracket up, plumbed it in. The pics can do the talking
    Now for the disbelievers that say cdtis already have a catch can so doesn't require one well I poked my finger inside the metal pipe before the intake and
    That's not a mist that's proper heavy oil LOL
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    Great mod! Well done.
    Regular Member wildchild's Avatar
    Sep 2011
    Wolverhampton
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 174000
    Thats a snazzy looking one m8 got a link for it pls buddy
    gaz
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Need to do this on my CDTI, I made a custom one using a compressor water trap on my 2.2, it sift through some right gunk!!
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Guess what i am doing soon, Great mod, i have had the same can sitting around for ages.
    Jan 2013
    rosyth
    Vehicle : vectra
    Trim : sri
    http://pages.ebay.com/link/?nav=item...d=221117129224
    That's what I got , easy to baffle so it will actually work as they wouldn't do fek all without it other than look pretty lol
    Thanks for the comments guys
    Aug 2009
    Trim : SRI
    Mileage : 50000
    What diameter of rubber breather hose do you need to connect can..
    Jan 2013
    rosyth
    Vehicle : vectra
    Trim : sri
    I bought 13mm Id 18mm od heater hose as its got good heat resistance and is internally reinforced to save it chafing through. Bit of a squeeze joining on the metal pipe to intake but bit of fairy liquid and it went on. Couldn't get original rubber off so cut it and used an inch of 15mm pipe to insert and join original and new pipe then jubilee clip as required
    Next up is to restrict egr soot flow till I can have it properly mapped out
    But for now hopefully this will allow my intake system to start a cleaning cycle
  1. Catch 22
    By icecube10111 in forum Engine & Drivetrain
    Last Post: 28th January 2013, 22:12
  2. Catch 22
    Last Post: 28th January 2013, 21:26
  3. You wouldn't catch me doing that......
    By gibbon7000 in forum General Chat
    Last Post: 19th September 2010, 13:26
  4. Catch Can
    By lizard in forum Engine & Drivetrain
    Last Post: 3rd July 2010, 20:41
  5. Catch me at PVS
    By Tibs in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2007, 22:04
vectra c stainless intake www.vectra-c.com
