Thread: clutch pedal really soft after new clutch
    Mar 2011
    Glasgow
    Default clutch pedal really soft after new clutch
    just fitted a new clutch new dmf and new bearing
    bled the clutch system
    the pedal feels really soft and when i push it right down only then do i feel some resistance but its right at the end,
    have i done something wrong
    mind you i cant actually start the car yet there seems to be an issue starting it (no eml codes or any other codes) so it must be a battery issue as the cockpit continously flashes even though i can hear the engine being turned over it wont start at all (lights keep flickering in the cockpit dash)
    so if i could get it started i would know if the clutch is ok or not
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Re bleed it might need a pressure/ vacuum bleed as they can be a nightmare to bleed fully.
    did you drop the steering rack? Check connector is fully seated.
    and check all earth straps
    Mar 2011
    Glasgow
    no i dropped one half of the subframe and the other half i just loosened up,
    steering rack was not dropped it was resting on top of the subframe
    which connecter is seated to what??
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Just thinking theirs no guarantee that theirs a connector. just thinking most usually have an electrical connector on rack and it can prevent starting as a safety precaution.
    Is crank sensor ok? Is turning fast enough?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Clutch not bled properly, Is it a flat battery?
    i have opcom if there's a fault code you want read
    Mar 2011
    Glasgow
    I checked all the codes nothing's coming up
    Going to try jump starting it
    Mar 2011
    Glasgow
    im getting the codes
    P0335 - Crankshaft Position Sensor "A" Circuit Open
    (29) - Present
    P0520 - Engine Oil Pressure Sensor/Switch Circuit Open
    (04) - Present
    they must be unplugged although i do recall unplugging something from the oil sump i didnt unplg any crank sensor
    where are tehse located| i think the crank sensor is the reason why it wont start
    can anyone help
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Correct crank sensor will stop the car starting, I think the sensor is near the starter motor. That's your problem.
    Mar 2011
    Glasgow
    problem solved was unplugged underneath and car now starts
    only problem is the clutch im having trouble bleeding it, the nut is also slightly rounded at the nipple
    can i replace these nipples??
    i am using a socket to loosen it and tighten it
    whats the best way to bleed this? gravity how long for?
  1. clutch has gone very soft
    By carl bear in forum Engine & Drivetrain
    Last Post: 13th September 2012, 15:48
  2. clutch pedal
    By Tam80 in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 19:41
  3. Clutch Pedal!!
    By andd306 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:48
  4. soft clutch
    By myelite150 in forum Engine & Drivetrain
    Last Post: 28th November 2009, 17:30
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
vectra suspension very soft
new clutch pedal very light insignia
