Thread: car wont start and lights in cockpit all flash on off
    Mar 2011
    Glasgow
    Default car wont start and lights in cockpit all flash on off
    I've just finished doing my clutch and built car all back together
    Checked all plugs are back in nothing unplugged
    Try to start the car (1.9 diesel) and it is starting I can hear it but just flashing lights in the cockpit
    Not sure if its the battery or something else can anyone else help
    Glasgow
    Flat battery. Get a jump start or buy a new one.
    Regular Member Johnsdutton's Avatar
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Wot he said
    Mar 2011
    Glasgow
    but the engine turns over and i can hear the fuel pump engaging (the engine was physically being turned over as normal)
    is this still the battery?
    exeter
    trust them i had the same issues . i could put the fans lights and everthing else on . but i could'nt get it to start . i thought it was my starter but i had green flag come out jumped it and he told me does'nt matter that everything works their was not enough jucie to do the starter and pre heater . a battery should read high than 12v he said it should be around 15v. try jumping it first
    Mar 2011
    Glasgow
    im getting the codes
    P0335 - Crankshaft Position Sensor "A" Circuit Open
    (29) - Present
    P0520 - Engine Oil Pressure Sensor/Switch Circuit Open
    (04) - Present
    they must be unplugged although i do recall unplugging something from the oil sump i didnt unplg any crank sensor
    where are tehse located| i think the crank sensor is the reason why it wont start
    can anyone help
    Mar 2011
    Glasgow
    problem solved was unplugged underneath and car now starts
    only problem is the clutch im having trouble bleeding it, the nut is also slightly rounded at the nipple
    can i replace these nipples??
    i am using a socket to loosen it and tighten it
    whats the best way to bleed this? gravity how long for?
  1. Wont Start
    By scottc in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2012, 19:56
  2. Help car wont start. 2.2 dti
    By Middo in forum Engine & Drivetrain
    Last Post: 25th June 2012, 23:09
  3. Replies: 10
    Last Post: 30th April 2012, 19:53
  4. car wont start
    By neill in forum Engine & Drivetrain
    Last Post: 16th January 2012, 23:00
  5. Will not start then it will then it wont????
    By djconfused in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:37
vectra 3.2v6 starting problems crank position sensor
