Results 1 to 10 of 17
Thread: smds for side lights
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default smds for side lights
    ive fitted smds for my side lights error free ones there ****** bright really good, only prob is they strobe when not on eg
    when the engine has started and there switched off they strobe until engine is off or you turn them on, i know people say the vectra dont leds and i understand that the pulse/strobe is the light out system but leds dont need that much power and the pulse is lighting them up hence the strobe, am i right?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    184 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Quote Originally Posted by chris1804 View Post
    .......... i know people say the vectra dont leds and i understand that the pulse/strobe is the light out system but leds dont need that much power and the pulse is lighting them up hence the strobe, am i right?
    Yes, pretty much fella. You would need to consider re-wiring the sidelight arrangements to have them "relay" switched if you are going to get around the problem. You can fit cancellers if needed, but all they do is fool the "system" into thinking you don't have a bulb failure. Apart from that it's back to "ordinary" bulb types, or live with strobing and hope it doesn't get used as an excuse to pull you over.
    Hanging Heaton
    24 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Just drive with your lights on... Have mine wired up but still drive round with them on
    Oct 2009
    Sandwell
    they do strobe like a cop car thats the thing. i dont want the hassle of getting pulled, or only other way is switch them on all the time but cant be bothered with that. are the indicators connected to the bulb out system? ill put them in side repeaters if i have to or number plate bulbs
    Hanging Heaton
    24 Post(s)
    Mileage : 140k
    Dash LEDs and number plates are only things not on the check...
    Oct 2009
    Sandwell
    ill post a pic up camera is **** but ill post it
    May 2012
    184 Post(s)
    Mileage : 131,000
    Yes, amazingly the lights are so cleverly thought out, that if the system detects a front sidelight out (when using them as parking lights is when I found out) the system activates the front indicator constantly so as to provide a safe alternative.
    So, you're either going to live with it, or rewire them via relays if you want to look "normal", or , revert back to normal bulbs.
    There are so many threads on this subject / LED's strobing , etc... It would be worth doing a search and reading what the other guys have done in similar circumstances.
    HTH
    Oct 2009
    Sandwell
    IMG00607-20130201-1943.jpgcheers for info , think ill just have them switched on all the time because they do look wicked, pic makes it worse, BB camera is **** in the dark
    Sep 2012
    dewsbury
    Vehicle : Vectra C Hatchback
    Trim : Sri
    Engine : 1.8 vvt
    Year : 06
    It's possible to turn on the front lights as DRLs so that they come on with the ignition, just got to remember to tun on the lights properly when it gets dark so that you have tail lights on.
    May 2012
    184 Post(s)
    Mileage : 131,000
    Quote Originally Posted by jason johnson View Post
    You can also turn on the rear lights too as DRL's if you want to
  1. Those of us with SMDs in the interior lights...
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 00:14
  2. side lights and number plate lights
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 19:59
  3. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  4. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  5. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
