Results 1 to 2 of 2
Thread: Rear heat window
    Jan 2013
    Newtyle
    Default Rear heat window
    hi everyone.... my heat window ar rear didnt work the button light on and fuse are fine.... what else should i check????
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    I had this problem,did a bit of digging around on here and found a couple of instances of the fuse in the boot being ok but in the wrong slot,checked mine and bingo fuse in the wrong slot put it into the correct position and it all worked,don't ask me why it had been moved because I don't have a clue,it had obviously been tampered with prior to my owning the car for what reason is beyond me
    But if yours has worked previously and just stopped recently I can't be of much help sorry
  1. Windscreens - Heat absorbing or heat reflecting?
    By Caveman_nige in forum General Motoring Chat
    Last Post: 4th February 2013, 22:09
  2. rear windscreen heat fix
    By leedslads in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2012, 20:02
  3. Rear Electric window
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2008, 02:23
  4. Heat rear window
    By Paul 360 in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2006, 22:19
