Results 1 to 3 of 3
Thread: Hid headlight fault
    Nov 2011
    clacton on sea
    Eek Hid headlight fault
    Hi I have a facelift 2006 signum with faulty headlights I am not sure if these are original headlights or a after market set ..my problem started when I started the car and switched on the lights ,,they started to dim then one went out .. If I put the lights on first then start the engine they stay on . Now things are getting worse last night pulled over switched off engine restarted and had no main beam lights at all . I also replaced the side lights some months ago and have noticed they flash when I've locked my car and walked away .. Please anyone who can help please speak up now its dark out there .
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Does your headlight switch have 3 or four buttons on it?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Sounds like you have a hid kit installed in your headlamps. & LED side lights. Led sidelights will flicker due to the car check system. Regarding your main beams, a set of new bulbs should solve it, if not then you will need new ballasts. This is all assuming you have a hid kit fitted.
  1. headlight connector fault ?
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2012, 18:52
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. strange headlight fault
    By toast in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2011, 07:26
  4. Vectra AFL Headlight fault?
    By Maddog1974 in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2009, 22:15
