Results 1 to 10 of 16
Thread: Emission light on
    Regular Member Porl's Avatar
    Apr 2012
    Barnsley, South Yorkshire
    Default Emission light on
    Hi
    I have an 06 SRI 1.8 VVT
    Engine been running smoothly since got the car, now done 12K in 10 months. Pulled away on a cold engine yesterday and lose of power followed by emission light came on.
    Engine judders when being worked now, a bit like the low revs pull away in first. Managed to do the pedal trick to get some codes for the problem and they are
    0304 - cylinder 4 misfired (which would fit with problem)
    0564 - not sure what that means
    Has any one had similar?
    Could it be the coil pack?
    Any help would be great.
    The car is booked in next week for a service (not been properly serviced since 2010 I reckon and done over 30k since then!!)
    Just wondered if anyone knew the possible bill am looking at to fix the emission light problem?!
    Paul
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    0564 seems to be cruise control
    misfire i would say coilpack check the plugs first
    http://www.vectra-c.com/forum/showth...highlight=0564
    what is the mileage?
    Apr 2012
    Just clocked 78K.
    The cruise control has been switching itself off at random times since I got the car 10 months ago.
    If it's not been serviced for 30K miles, the oil will be useless
    It is well documented that life expired oil can cause the Emissions Warning Light and throw up false warning codes
    The warning codes are correct but are a cause of the engine trying to work with the life expired oil
    Sadly you need to wait 48 hours for the Emissions Warning Light to clear
    Normally it activates the Safe Mode when detected, and this may be the erratic revs experienced
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Try spark plugs first as its the cheapest option, if not coil pack. As for the cruise control most likely then clutch pedal switch.
    Apr 2012
    The oil was changed 10 months ago when I bought the car and they put a new battery on, don't think they did much else though. Certainly no filters were changed.
    Is that 48 hours of no activity or just 48hours?
    Quote Originally Posted by Porl View Post
    Once the Emissions Warning Light has activated it requires a full 48 hours to reset, it just remains on as a warning
    Apr 2012
    So the problem has been sorted along with a few other issues.
    1. new plugs to sort out misfire on cylinder 4 - luckily avoided need for coil pack
    2. new rear shockers are near side had failed and leaked over rear brakes
    3. new rear brake pads
    4. full service inc all filters and oil
    5. 4 wheel alignment to sort out uneven front tyre wear
    Got the car back after 2 days in garage, quite happy with the results, it should drive much better and more economically now!! All for £350, a bargain!!
    Thanks for the advice, again
    Happy motoring (again!)
    Paul
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Paul
    glad to help mate
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Paul
    does your cruise control work ?
  1. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  2. Emission light on.
    By ExclusivDoug in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 10:36
  3. emission light help!
    By platty in forum Engine & Drivetrain
    Last Post: 22nd August 2008, 18:09
  4. help with emission light
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 10th July 2008, 02:02
  5. emission light
    By pipamish in forum Engine & Drivetrain
    Last Post: 20th March 2008, 08:29
vectra c 1.8vvt emissions light
