Thread: Towbar bolt sleeves question/help required
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    Default Towbar bolt sleeves question/help required
    Hi
    so long story short i bought a towbar didnt come with the sleeves for the bolts.
    was wondering if anyone knows where these can be purchased seperately or if some kind person has a towbar not fitted to their car atm would they be able to quickly measure the sleeves so i can make my own from round bar or something.
    THANKS all help much appreciated
    Regular Member megsdad's Avatar
    May 2011
    Northwich, Cheshire..
    13 Post(s)
    Vehicle : SRi Estate Nav
    Trim : Boring cloth
    Engine : CDTi 150
    There are 6 tubes/sleeves in total.... 4 are 119mm long and 2 are 119mm long, they are 18mm O/D. The 2 longer ones go nearest the rear bumber. In the boot floor there should be 6 divets (on the boot floor on top of the chassis runner) these should be drilled out to 19mm.
    Hope this helps.
    Steve
    Engine : 1.9 CDTi
    I think you miss typed one of the measurements
    May 2011
    13 Post(s)
    Trim : Boring cloth
    Engine : CDTi 150
    oops...sorry, 2 of the tubes are 18mm O/D 136mm long and 4 of the tubes are 18mm O/D 119mm, as i said previous the longer sleeves go nearest to the rear bumber.
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    thanks for reply mate and for the pm
    my bar has only 4 bolts with it, but on closer inspection it does have 6 holes in it. the middle holes are the ones i am missing the bolts for. hate to trouble you more but what sizes are the bolts? and do you know the ID of the sleeves thank you so much
    btw the guy i got it off said it was fitted to his car like this, with the 4 bolts and no sleeves! sketchy!
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    just had a quick look at the bar it doesnt have holes for bolts in the middle, just front and rear and the bolts are all the same length. i didnt measure them so dont know what that length is but the rear ones are definitely not longer as took them all out and set beside each other. its a bosal, going to try to find more info on google.
    Aug 2010
    Leeds
    I got some made from Metal Supermarkets if you have one of these places were a few quid.
  1. GM Wiring Towbar question
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2011, 08:07
  2. towbar question
    By vauxhall-john in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 20:05
  3. Towbar question regarding fitting
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2008, 16:45
  4. Signum Towbar Question
    By decho in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2006, 19:35
tow bar bolt sleeve
