Results 1 to 10 of 20
Thread: Dead car
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Dead car
    Hi the car is dead went to start it today and nowt the only light on was the yellow/orange light the emission one and on the clock was a f does this mean something
    Thanks steve 120cdit
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Engine management fault
    So needs to go on a computer to find the problem
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    You'll certainly need to see what codes are logged. On my petrol you can do this using the pedal test, but I believe some diesels won't let you do this - a code reader may be needed.
    Ok thanks m8 check when I get home
    Dec 2011
    Seaham
    Have you got a code reader?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Do you have a multimeter?
    Yes my father in law has a multimeter also have a code reader the one we carn't talk about but will clear all faults
    Right the wife has just said that the battery has no light indicator on with the keys in or out would this point to a new battery
    Same battery from new I think it's a 55 reg
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Check battery voltage would be first starting point.
    do you get any other lights at all?
    any clicking noises?
    if you get no other likes or clicking noise.
    if you turn your hazards on And try again does that make a difference?
  1. is my cat dead?
    By victorM in forum Engine & Drivetrain
    Last Post: 29th September 2011, 21:34
  2. DTI Dead!
    By si_hoss in forum Engine & Drivetrain
    Last Post: 26th September 2011, 11:11
  3. It's dead!!
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2011, 15:00
  4. Dead PC - HELP
    By Leemarksmith in forum General Chat
    Last Post: 1st January 2011, 23:52
  5. Very dead car....
    By danBoy in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2010, 13:08
