Results 1 to 10 of 19
Thread: sticking caliper
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Default sticking caliper
    Hey, think I have a front caliper sticking as a can hear it squeal until I hit brakes and it clears. Any quick fixes apart from new caliper?
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Push the piston back in, copper grease the side and back of the pads, obviously not the disc side, and generally a good clean up.
    Wiltshire
    Mileage : 150000
    me being basic mechanic, is there a how2?
    Dec 2011
    Seaham
    Squealing brakes are often caused by missing Anti Squeal shims behind the brake pads.
    Wiltshire
    Mileage : 150000
    Quote Originally Posted by Ben50n View Post
    Ok will check
    Dec 2011
    Seaham
    As a matter of interest, have the brake pads been changed lately? Also if you do not use your car for a few days, you do get a build up of rust on the disc faces, which clean off the first time you brake.
    Sorry may be stating the obvious...
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    To check there really seizing, from cold go for a few min drive with minimal breaking then pull over and check your discs for heat... One you lose your finger prints to is seizing
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Quote Originally Posted by leemarksmith View Post
    Another heat check option is to spit on the disc...less painfull
    Regular Member coldo's Avatar
    Scotland
    Easy to free off. Follow the how to for changing the pads... But instead of replacing them you are just freeing them off. I had an issue with a rear one recently. I wire brished it, break cleaned it and used white crease when winding it back. loads of copper crease on the pads (not the break disk side) and it has been great ever since.
    The rubber gater arround the piston had perished at trhe base so I'm looking at a new caliper at some point soon
    23 Post(s)
    Mileage : 110k
    Can the handbrake cause binding, just remembered I've had to unhook it from the near side due to this, don't know wethere it needs a new handbrake cable or the spring mech is dodgey, although it feels free?
  1. Rear wheel getting warm caliper sticking?
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 17:29
  2. 1.9 CDTi rear caliper sticking
    By Tennants in forum Suspension, Wheels & Brakes
    Last Post: 14th October 2012, 13:06
  3. sticking
    By HARRY SRI in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2012, 22:23
  4. sticking egr?
    Last Post: 11th July 2010, 20:01
  5. Brake Caliper Painting/Caliper Decal's??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 21:14
vectra fns brake stick
vectra c caliper build
vectra c front brake caliper sticking
front brake caliper sticking when it gets warm on a vauxhall vectra c cdti
