Thread: help cant get dmf flywheel off 1.9 cdti
    Mar 2011
    Glasgow
    Default help cant get dmf flywheel off 1.9 cdti
    I'm having alot of trouble getting the flywheel off I can't get it off it keeps spinning I used a small crowbar to jam it somewhere but when I turn my large breaker bar it only lifts the engine up and the crowbar falls off.
    What can I do? I've used an electric impact gun and this won't remove it my impact gun sore up to 450nm
    The new bolts came with threadlock so I also tried applying heat and not budging at all
    What can I do my car is stuck here
    Mar 2011
    Glasgow
    it's ok i got it off sorry for post
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    did youbresort to burning gear lol
    Mar 2011
    Glasgow
    no i don't unfortunatley have anything but cheap blow torches from halfords, that didn't work either
    just had to screw in a bolt into the gearbox and get someone to hold the crowbar whilst turning the bolts, freaking nightmare!!
    anyway im going to finish the rest of the job tommorow, going to temporarily bolt the new clutch with plate to the new dmf and then using 3 leg pullers going to mimic clutch depress and make sure that the clutch plate still spins freely then going to bolt it all up
  1. solid flywheel kit cdti 150
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2012, 17:32
  2. Looking for cdti 1.9 150 flywheel
    By LEW1S2006 in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 15:10
  3. SRi 150 Cdti Clutch/Flywheel Going Gone..
    By Imi in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2008, 16:47
  4. Signum CDTi Flywheel Vibration
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 16th November 2007, 22:09
