Results 1 to 10 of 11
Thread: Retrofitting front fogs help needed
    Oct 2012
    Birmingham
    Default Retrofitting front fogs help needed
    Right I've fitted frot fogs to my preface lift 2.0 stil change switch loom and they don't work anyone had the same problem ?
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    58 Post(s)
    Vehicle : Exclusive
    Trim : Vxr half leather
    Engine : 1.9 cdti
    Year : 56
    I think you need to tec2 it as the car needs to know there fitted.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    You need to change the fusebox in the engine bay(UEC) for one that supports foglights then program the UEC, Dashboard and BCM.
    Oct 2012
    Birmingham
    I thought that was only on the facelift model with full canbus
    Oct 2012
    Birmingham
    All that just to run fogs sounds a bit much
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    As far as I know I am the only one on this forum to have retrofitted a full factory foglight set up. I tried 3 different UEC's until I found one from a 2002 Elegance, Ident AK, that worked.
    http://www.vectra-c.com/forum/showth...!!!&highlight=
    Previous to that I had them working through a Relay and switch on the dashboard.
    Oct 2012
    Birmingham
    Well I might just wire it to the actual fog light switch so Ido t have to have second switch for them how easy it to change ?
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Quote Originally Posted by Das View Post
    no m8 ive done a fair few in me time.
    as already mentioned normally you need another uec that supports
    front fogs then a bit of programming to activate them.
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    The UEC? 4 torx bolts and the live wire from the battery. If you could pick one up cheaply you could try fitting it and see if it works. Mine worked without programming but I put it down to the fact that in a previous attempt, using a full can UEC, Im pretty sure the guy activating it with Tech2 had set the BCM and dashboard to Present, but when it didnt work properly those settign were just left as the were. Would be nice to see someone else get a factory set up working.
    Wiring them up to the rear foglight switch wont work because of the canbus system, unless you add in a latching relay. Or run a wire all the way to the loom at the rear of the car. TBH a separate switch on the dash worked fine for me for nearly 2 years, it was just a project that i started that I wanted to finish properly.
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by andy.l View Post
    Ah cool, never seen any other posts before.
  1. Help needed fitting H3 HID Fogs on to Facelift
    By Envy in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2012, 19:54
  2. 06 2.2 sri front fogs
    By 06sri in forum Bodywork & Interior
    Last Post: 18th June 2012, 19:49
  3. front fogs
    By cbl1985 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2010, 19:10
  4. Front Fogs
    By parapaul in forum Styling
    Last Post: 18th July 2006, 22:16
