Results 1 to 10 of 14
Thread: engine fails to turn over
    exeter
    Default engine fails to turn over
    i have a 2.0 dti y20dth engine and i went out this afternoon went to start it and all i got was 1 rotation and it stoped and now all i get is it clicking from under the turbo . i have checked the battery and its got full volts . and everything works like windows cd player and lights . does anyone know what it could be . i am thinking it could be starter motor but i would like to make sure first . as a starter if £150 plus surcharge of £132 on top ( £282) .
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Try a jump start. Sounds like a knackered battery or alternator. The clicking is the starter solenoid engaging.
    exeter
    the battery is fine i can put the lights on when trying to start it but all they do is dim but stay on . and then once i stop trying to start it the lights come bright again . and i have checked the battery with a mutimeter and it show 12.7 volts
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    What does it drop to when cranking? Still sounds like a knackered battery if the lights are dimming with just attempted cranking. Should be anywhere between 9.5 or so and 11 when cranking. 9 or below and the battery has had it.
    exeter
    i just put the tester on while cranking it and it showed 10.5 . the longer i try and start it the more clicking a get
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Try a jump start with the other car running this will rule the battery out if you get the same symptoms. The next step would be the starter motor imo.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    does sound like you have a flat battery
    but try measure volt to starter motor while someone tries cranking.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Battery or starter motor. A jump-start will confirm
    Glasgow
    IT IS the battery. The lights get dim because the starter system is drawing the electricity it has left. The clicking is relays and electrics kicking because it does'nt have enough juice. It is 110% needing a new battery at the least.
    exeter
    Quote Originally Posted by Critch View Post
    i cant get to it . its behind the exsaut manifold and behide a heat sheid . right under the turbo
  1. Car fails its MoT again
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2012, 13:19
  2. Febuary,s fails
    By bobssignum in forum Comedy & Humour
    Last Post: 4th March 2012, 10:23
  3. 1.9cdti engine wont crank or turn over
    By Turbomanrony in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd January 2012, 11:01
  4. slight noise from engine when i turn it off ,v6 turbo
    By pogo in forum Engine & Drivetrain
    Last Post: 21st July 2011, 07:20
  5. Engine or clutch seems to rattle when turn car off !!
    By bradie1974 in forum Engine & Drivetrain
    Last Post: 18th March 2010, 16:30
