Thread: cruise control
    Regular Member eminemme42's Avatar
    Jan 2012
    westmidlands
    Default cruise control
    cruise control turns itself off on its own going down the road
    pete
    Regular Member John Bishop's Avatar
    Oct 2010
    There is a How 2 on removing the stalk to clean the contacts on the site. 10 min job. It could be that or the clutch spring switch.
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    Quote Originally Posted by eminemme42 View Post
    pete
    Are you sure you're not touching the brake or clutch pedal with your foot? Touching either, even lightly, will turn it off.
    Jul 2011
    UK
    Year : 06
    What john said the stalks do play up and need a cleaning
    Jan 2012
    westmidlands
    Quote Originally Posted by Hue Jarse View Post
    no mate i was on motorway and all of a sudden it just turns off
    pete
    Jan 2012
    westmidlands
    took stalk out give it a thourogh clean still the same
    pete
    Regular Member Chris R's Avatar
    Jan 2008
    Leamington Spa
    mine does the same, ive cleaned the stalk also and it still persists
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    On my 2002 vectra the clutch pedal return spring had broken meaning the clutch pedal didn't return all the way and prevented the cruise from coming on unless I pulled the pedal up with my foot. If yours had broken it could be making the switch sometimes (therefore cruise works) and then dropping slightly and turning cruise off (ignore this if you have an automatic). I bought an add-on spring mechanism from the dealers to fix it
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
