Thread: baffled?????????
    liverpool
    Default baffled?????????
    to try and find source of water in boot (have replaced aerial base and sealed it already) have today looked at rivet under roof rail. it is slightly loose - should it be? so poured water, then put hose pipe on it, but no water. decided to check aerial again, no water. put hose over rear lights, no water. bit stumped now what to do next.
    on a plus point did receive me heko wind deflectors
    Jul 2011
    UK
    Year : 06
    The join at the rear bumper when u open the boot next to the rear lights there is a gap where the bumper start water gets in there
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    Open the tailgate and have a look at the seam sealer in the circled area where the panels join, seen a few leak here in the past...
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by Spelly View Post
    <img src="http://www.vectra-c.com/forum/attachment.php?attachmentid=68443"/>
    That's where water runs down then down to the bumper bit seal all the gaps under the boot lid
    liverpool
    Thanks for help. Will check both areas. The water does appear to be coming in by fuses. Can see water stains running down and when open side compartment its wet on boot floor. Not today however.
    Sep 2012
    dewsbury
    Vehicle : Vectra C Hatchback
    Trim : Sri
    Engine : 1.8 vvt
    Year : 06
    Seal around the rear quarterlight?
    Derbyshire
    Quote Originally Posted by eve01rton View Post
    Mine leaked in the circled area, the seam sealer had very tiny cracks in it from age / weathering. If its leaking in this area water will run down the inside of the pillar channel, put your head in the boot (fuse box area) and look directly upwards towards the parcel shelf supports. There is a metal channel that comes from the roof/pillar area, this is where the water will appear if its leaking from the seams. Hth.....
    liverpool
    After doing my water test and no water leaking in I never used the car for 2 days while in work. Before I used it today checked boot again and dry. However after driving round for bit looked in boot and quite a lot of water again in spare wheel space. So does this help anyone in knowing were leak is as its obviously collecting but not leaking thru into movement of car dislodges it.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Rear Quarter glass is a common water ingress area mate, you have to take out all the side inertia boot panel to get to it properly.
    Jul 2012
    Doncaster
    How about the rear washer jet? Seeing as it happens when the car is moving, just an idea?
  1. A bit baffled,and nervous!
    By toaffer in forum Engine & Drivetrain
    Last Post: 7th February 2013, 20:24
  2. Baffled by tuning boxes
    By Teapot in forum Diesel Engine related
    Last Post: 30th December 2010, 22:35
  3. baffled
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 21:02
  4. MSN Baffled
    By JSYSH466Y in forum General Chat
    Last Post: 9th June 2009, 16:45
  5. baffled or unbaffled
    By alex in forum Diesel Engine related
    Last Post: 20th April 2009, 07:31
