Page 1 of 10 123 ... LastLast
Results 1 to 10 of 91
Thread: No boost until 2400RPM - CDTi 150
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default No boost until 2400RPM - CDTi 150
    Evening everyone.
    I've got a boost problem and I'm a bit stumped by it. I replaced the turbo about 1200 miles ago and it was fine. Spooling up like normal at about 1700RPM. It seemed to get a little worse but I thought nothing of it until a couple of days ago when I went to accelerate like I normally would on the motorway in 6th gear. Nothing. Tiiiiiiny increase in speed but that was it. After a bit more driving around some A roads the turbo isn't really spooling up until 2400 or so RPM, then it goes like a rocket like normal. There's hardly any pull at all before that.
    I've replaced the vac pipes from the vac pump to the boost solenoid, and the one from the solenoid to the turbo. The boost sensor was cleaned about 3000 miles ago, and the EGR has been blanked off for about 10,000 miles.
    Run out of ideas now!
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    whats ya pedal map set at with ya boost and limiters mate
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    It's running a pretty standard map just with EGR delete still. Just can't work out why it's gone from driving fine to driving like crap. Boost peaks at 25psi like it used to on the old turbo, just takes ****** ages to get there. Not had chance for it to be setup on the rollers yet. It'll be done this month when I get a break for a bit!
    Swirl bar is still on the manifold too.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    have ya got a hybrid on it now matey
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    give yer boost pressure sensor a clean with some carb cleaner but dont scrub it , let it soak .
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by paulvectrac View Post
    Yeah. Its driven fine for about 1200 miles on the old map. It's only just started to do this which is why I'm stumped. If it was straight away after the swap I'd go straight to the map but its been fine for ages.
    Shinby1 I'll go over it again at the weekend when I can pull it out. Cheers.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you got any of the data to hand?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Not at the minute no. Forgot to pick up my diagnostic bits. Got the cable but thats it. >.<
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    tell ya what diss the battery then leave it a hour or so see what hapoens i bet its right then
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'll pull it off later today for a couple of hours. Fuel consumption has gone up too. Normally use half of a tank doing Wirral to Cornwall but it's gone up to nearly 3/4 of a tank this time.
  1. cdti boost gauge
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2012, 20:20
  2. v6 cdti boost
    By broad in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2012, 16:25
  3. 1.9 CDTi turbo not kicking in till 2400rpm
    By Ginge7289 in forum Engine & Drivetrain
    Last Post: 12th December 2011, 10:41
  4. Cdti boost guage
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 20th April 2010, 21:08
  5. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
vauxhall signum not boosting till 2500 rpm boost leak
vauxhall signum not boosting until 2400 rpm
vectra cdti low boost site:www.vectra-c.com
vectra c not boosting
